The Tunecast Auto Universal
Intro: The Tunecast Auto Universal
I got tired of always having fuzzy reception from my car FM adapter, which is the Belkin Tunecast Auto Universal. There's a few tutorials around, but none for this particular model.
There are a couple of really easy things you can do to boost the transmission power. It seems to make a pretty significant difference to the reception.
The thing is a little tricky to tear down, so I'll post some photos of that process.
Here we go...
*** Disclaimer: Boosting the output power may cause your transmitter to exceed FCC regulations on unlicensed FM transmitters. Neither Instructables nor myself assume any responsibility for your actions; this instructable is provided for learning purposes. You should accurately test the output power of your transmitter to make sure it is within regulation or you may incur a fine or other penalty.
Here we go...
STEP 1: Remove the Buttons
The buttons are pretty easy to take off. You can just pry off the "U" shaped preset buttons, which click back into place easily.
The up/down tune buttons are secured to the face with adhesive. You just have to pry up the buttons and deal with the fact that you might have to reapply adhesive. These need to be removed since there's a screw underneath.
STEP 2: Remove the Screen Window and Case
The next thing to take out is the plastic window protecting the screen. It has small tabs that stick into slots in the outer shell, in addition to being glued to the underlying case. Use a screwdriver to loosen up the case, then carefully pry up the window, adhesive and all. Be careful not to gouge the screen if you are using a tool for this.
Once the window is off you can unscrew the FIVE screws (black one in the center) and pry the case off. Again, watch out for the screen.
STEP 3: Get the Circuit Board Out.
Because of the top screw posts this is easier said than done; they are a pretty tight fit through the PCB. Just get a flat object and try to lift the board out as evenly as possible. Be careful not to scratch off any circuit components, and watch out for the flexible screen connector! It looks breakable.
STEP 4: Find the Inductor and Antenna Wire
The two ways to increase power output are:
Bypass the inductor (small black box)
Lengthen the Antenna
By taking a short, 2cm length of wire I had laying around I was able to noticeably increase the transmission power. I sat in my car, tuned to a fuzzy station that had a little bit of some station coming through. I tuned the Belkin to the same station and started playing some music - very fuzzy, cutting in and out with the local station. When inductor was bypassed as shown in the last picture, all I could hear was MY music, and much clearer. I then used the same 2cm piece of wire and touched it to the free end of the antenna - this also had the same effect.
STEP 5: (semi) Permanent Modifications
The most permanent way to modify this board is to completely unsolder the inductor and replace it with a 0 ohm surface mount resistor that fits the pad size (my guess is a 1206 will fit the pads best, maybe with a little fudging) . However, I am leaving the inductor on and just soldering a wire over it to bridge it. This should have the same effect, as the 0 ohm wire and the inductor will be in parallel, and thus the resulting impedance is... 0 ohms.
The next step is to desolder the antenna wire and replace it with a longer one. You can use any length you want, as any increased length will be useful. A quarter wavelength antenna would be ideal. This length is about 76cm:
c / f = wavelength
where
c = 3E10 cm/s
f = ~ (88+108)/2 = 98 MHz (average FM frequency)
--> wavelength = 306cm
--> 1/f wavelength = 76.4 cm
If you usually use just one or two stations near eachother, you can fine tune this length to be specific to those frequencies, but I doubt such small adjustments will make a noticeable difference.
Pictures / more steps to come (soldering this evening)
c / f = wavelength
where
c = 3E10 cm/s
9 Comments
lahirurandika.ranasinghe 6 years ago
Thanks for your great help...
rwebber81 9 years ago
I received a Tunecast Auto with the 30 pin connector for Apple Products. Is there any way these can be fitted with a 1/8" male connector like the Tunecast IIs?
simondumais1 8 years ago
Yes and you can even charge your phone if you wish! Cut the cord at the 30 pin connector.
The Red(+) and Yellow(-) wire wraped in blue foil is for charging.
The "big" white wire contain the left, right and ground for audio signal (Green, Yellow and Bare).
You need to connect the small brown wire to the charge port ground (yellow wire)
The small Blue and the White wires are not used as these were for data transmission with the tunecast app on the Iphone/Ipod
Hope that help!
P.S.: I included some pictures of my WIP setup.
For the Audio, Left is Yellow, Right is Green, and ground is bare.
jimtran93 10 years ago
Looking to do some kind of antenna amplification using an op-amp (the LM 741CN to be exact) I have handy thanks to my introduction to electronic circuits course. Any know if it would be as simple as wiring up the antenna connection to the non-inverting input (along with setting up the V+, V-, and feedback resistors, etc)?
twocvbloke 12 years ago
I wasn't as scientific with my mod though, I just slapped a long dangly wire onto the antenna points and soldered the opposite ends together, works great and has a god range... :)
solis365 12 years ago
I put a long dangly wire on it but eventually it broke off and I had to solder a new one on... kind of a pain.
lucky me, now I have bluetooth enabled radio so I don't have to fart around with this thing any more ;)
justlaxn529 13 years ago
the other thing to make sure of is, if you are using stranded wire, that none of the strands are loose and shorting anything on the board out.
