The Ultimate Helping Hands
Intro: The Ultimate Helping Hands
I'm sure that most makers and electronics enthusiasts have encountered the dreaded cheap helping hands that continue to tip over at any and every opportunity, generally ruining the current project. i'm also sure that many of you have looked at better vices and helping hands, the problem with these is the price! a popular model can cost as much as £40/$57. So, in this instructable i aim to show you how to turn some cheap helping hands and some other junk into the ultimate PCB vice!
STEP 1: Gather Materials and Tools:
Before you go about creating this project you need to find a few things, most of the parts can probably be found in your parts bin, failing that you can go to your local scrap yard/dump and see what you can find there.
Materials:
1. cheap helping hands. Gearbest Eu+Us
2. Large transformer*
Tools:
1. Hot glue gun. Amazon EU+US
2. drill/pillar drill.
3. metal cutting drill-bit. Amazon EU+US
*transformer or other heavy metal object. these can be commonly found in: microwave ovens, fridges and power supply units.
STEP 2: Assembly:
step 1: take off all of the parts from the helping hands, leaving only the alligator clip assemblies intact.
step 2: attach the rod directly onto the base with one of the connectors.
step 3: push both alligator assemblies onto the rod, make sure to tighten them so they don't get in the way later.
STEP 3: Base Assembly:
step 1: put the drill bit in the chuck of your drill, make sure that the bit is the same diameter as the shaft of the helping hands.
step 2: mark the location that the shaft lines up with on the side of the transformer.
step 3: drill a small pilot hole to allow you to centre the larger bit.
step 4: slowly drill into it with the larger bit whilst dripping coolant onto the hole.
step 5: clean out all the swarf from the hole and start heating up your glue gun.
step 6: fill the hole with glue and quickly push the rod into it, make sure to align it before the glue dries.
7 Comments
Lavoz24 8 years ago
Thanks for sharing! I was looking for a better way to use my "hands" as I bought the cheap one not knowing about the weight issue. I made a bigger base out of a bowl and used fish tank rock I had left over and it works great. My only issue now is I can't seem to tighten the clips enough to hold up my project so I end up pushing it down when I solder or desolder. I will try your way but here in lies the dilemma, unless it comes with a magnifying glass attachment the helping hands come with only one of those bar attachments you used for your alligator clips so where can I find another one? If I don't have one on hand, is there something else I could use?
b4polaris 7 years ago
I usually use a screw/bolt with the same diameter as the shaft of the clips. Keeps them from collapsing, and adds a little weight to the whole unit.
MakerBox 8 years ago
Stan1y 8 years ago
voblak 8 years ago
