The Useless Box
Intro: The Useless Box
This Instructable teaches you how to make the useless box. Good luck and have fun!!!
For more awesome projects, please visit: http://www.berbawy.com/makers/
Equipment that you will need:
Hot glue gun
Soldering equipment (Solder, soldering iron, etc)
Screw Driver
Laser cutter (Saw if no laser cutter available)
Materials that you will need:
Standard Servos (http://www.amazon.com/Futaba-FUTM0031-S3003-Standa...)
DPDT switch (http://www.amazon.com/TOOGOO-125V-Position-Toggle-...
Micro switch (http://www.amazon.com/uxcell-Micro-Switch-Roller-A...)
Hinges (http://www.amazon.com/Source-Clear-Acrylic-Plexigl...)
Scrap wood pieces
Acrylic pieces
STEP 1: Moding the Servo
Take apart the Servo by unscrewing the 4 screws holding the servo together.
STEP 2: Moding the Servo
Use a pair of wire cutters to cut off the 3 wires.
Also cut off the wires from the input connectors.
STEP 3: Moding the Servo
Using only 2 of the wires, strip it, and solder them to the connections shown above.
STEP 4: Moding the Servo
Open the top side of the Servo and remove the gears
Use a pair of cutters to cut of the plastic tip of the servo, as shown above.
STEP 5: Moding the Servo
Also clip of the little nob on the one of the gear , shown above.
Finally, put the servos back together.
STEP 6: Wiring the Servo
Solder the battery pack (on the outer pins)
Solder the Servo (middle pins)
Making sure the positives/ negatives are on the same side.
STEP 7: Wiring the Servo
Solder a piece of wire from positive wire of the battery (top left) to the empty pin across from it (bottom right).
Solder the micro switch using extra wires to the negative wire of the battery (bottom left) and the empty pin across (top right).
STEP 8: Finishing the Servo Arm
Laser cut out a wooden piece of swing arm.
Attach the arm to the servo using screws.
You can make as many as you desire. ( I made 3 in this case)
STEP 9: Making the Box
Laser cut out the required pieces to make the box.
And construct it using hot glue or other type of glue
STEP 10: Putting It All Together
Attach the Servos to the inside of the box.
Drill holes that align with the arm on the top piece of cover.
Glue in the micro switch so when the arm swing back, it touches the micro switch.
STEP 11: Done!!!!
Finally attach the covers using hinges. and you are ready to go!!!!!
10 Comments
mrwonton 6 years ago
you want to open it, but the box thinks otherwise! :)
tomatoskins 8 years ago
This is excellent! I'd love to see a video or a gif of it in action!
FelipeBecerra 8 years ago
me too!
weipeng0330 7 years ago
I have added a video!!! Check it out!!!
I have added a video!!!! Check it out
weipeng0330 8 years ago
tljiha 8 years ago
Gelfling6 8 years ago
Not criticizing, but, leaving the servo control electronics, despite clipping the potentiometer shaft, and removing the limit tab from the main drive gear, But isn't the "H" bridge raising any problems with the motors reversing? If you’re going to convert the servos to direct-drive motors, you might as well un-solder the board completely, before connecting the wires to the motor.. and with the board, the whole potentiometer should come loose (Futaba 3xxx models, the potentiometer is just snapped into position..) and then, clip the limit tab.. less steps.
Meglymoo87 8 years ago
Hahahah XD
