The Amazing Pringles Stirling Engine
Intro: The Amazing Pringles Stirling Engine
The amazing pringles Stirling engine, made from cardboard Pringles tube. When I saw this video by MarekSHayward I just had to have my own! It impressed me seeing a Stirling engine made mostly out of cardboard, something which wouldn't normally be workable in an external combustion engine. This is a really easy to build Stirling that should be accessible to almost anyone.
How does it work ?
This engine uses air which is repeated heated and cooled. To allow the air to be heated and cooled the pringles tube contains a displacer which is like a loose piston that can move up and down forcing the air around the engine. When the air is heated it expands pushing the diaphragm (balloon) outward which turns the cranks. When the cranks turn they move the displacer down so that the air is near the top where it is cooled causing it to shrink and pull the cranks back, which of course moves the displacer upwards allowing the air to be heated at the bottom, this repeats over and over!
Materials :
Tools :
How does it work ?
Materials :
- 4 x Pringles tubes, clean and dry
- 1 x Balloon
- 1 x Air freshener lid/ small aerosol lid
- Cardboard from an old shipping box
- Several plastic straws
- General purpose adhesive
- Hot melt glue
- Fishing line (the creator of the original engine used cotton thread instead)
- Cotton wool
Tools :
- Scissors
- Compass
- Drill (with 2mm and 5mm drill bits)
- Mark pen
- Pencil
- Ruler
- Pliers
- Box cutter
- Hot melt glue gun
66 Comments
Shwen1 9 years ago
is the only way to get the directions through the download that costs money?
scraptopower 9 years ago
No, go on my website scraptopower.co.uk. They are all free on there.
ZoeS34 6 years ago
the website doesn't work for me
watson9194 13 years ago
thanks
darcy2456808 7 years ago
how do we extract the energy?
heathbar64 11 years ago
A Das 11 years ago
I tried searching for the steel wire wool for the stirling engine fan but it wasn't available anywhere around. Could you suggest any alternatives which would work without fail?
Waiting for your reply,
Thank You
ankitcoolmaggu 12 years ago
scraptopower 12 years ago
inventorrr 12 years ago
firstly we made a tube with the piston and cotton wool. but where did that tube
rmoha 12 years ago
000Ike 12 years ago
1. does the stirling engine keep working infinitely until there is no more heat?
2.would hot water be a safer alternative to fire? to use the steam as heat.
- thanks
Hot water wouldn't be hot enough to run this engine, unfortunately.
Nirnaeth 12 years ago
