Introduction: The Cutting Seat Is Pasted in the Helmet
The helmet and the cutting seat are prepared
Step 1: The Mount of the Cutting Seat Is Peeled
Noting, it peels the mount
Step 2: Position of the Seat Is Decided
Position of the seat is decided vis-a-vis the helmet
Step 3: [goshigoshi] It Does With the Cloth
In order for the air not to enter, from the center it rubs with the cloth
Step 4: In Order for the Wrinkle Not to Approach, It Cuts
It cuts with the scissors
Step 5: Temporarily, It Could Paste
As been able to paste well, it is visible, butâ¦
Step 6: The Protective Paper Is Peeled Off
Slow, paying attention, it peels off the protective paper, this time, the protective paper when you raise to directly above, is not good. It peels off alongside the curved surface of the helmet.
Step 7: Completion!!!
It could paste well, also everyone will try challenging
24 Comments
15 years ago
I want a helmet, toooo. It puts the lotion in the basket. :)
Reply 15 years ago
Uh?
15 years ago
In fact, I participated for a lecture of technical writing in Japan which there was on February 21. I am lacking in explanation in "helmet contents" and think that, in addition, various deficiency was full. I showed it in Japan in the middle of the night of February 20. I was surprised to get up in the next morning and did not think that there was a response so early. Thank you once again.
15 years ago
Your grammar needs some help.
Reply 15 years ago
You think that the [me] it is do, with automatic translation it has become meaning unclear.
Reply 15 years ago
What? How ironic.
Reply 15 years ago
It smacks of BabelFish to me...
Reply 15 years ago
It is, is but I use the automatic translation of google
Reply 15 years ago
Oh, a translator, ok.
Reply 15 years ago
15 years ago
I actually use to be a vinyl cutter This is quite humorous I can try to translate intro) The vinyl is cut, peeled, taped & trimmed. Clean the helmet surface 1)The backing is peeled note the graphic is upside down, peel the backing away 2) pretty easy, line it up 3)use a cloth to push out air bubbles starting from the center working outwards 4)cut slits to help reduce wrinkles 5)You may be able to pull it off and reposition or start over If you did not break the adhesive beads 6)peel the transfer tape off slowly Do not pull up rather at a downward angle 7)I have no idea They can try but no one will have a bad ass helmet like yours
Reply 15 years ago
Comment thank you, you pay attention from next.
Reply 15 years ago
Advice thank you, you pay attention
15 years ago
What kind of print is the decal that you are applying?
Reply 15 years ago
We asked to the professional trader, it is something of the vinyl film make. It transferred the illustrator manuscript of Mac, had cutting. Because several colors you use, it became expensive ones.
Reference: Cutting seat manufacturer sight
http://www.cs-nakagawa.com/index.html
15 years ago
Hai! Domo arigato gozaimasu kanekanegongon-san. Zenryo na sashizu.
Reply 15 years ago
Are you japanese?? You just said thankyou very much. I am japanese too!
Reply 15 years ago
So, is, it is the Japanese, please to be possible
Reply 15 years ago
Arigato gozaimashta.
Reply 15 years ago
ie ie Do-itashimashite ! korekaramo yoroshiku Onegai-shi-ma-su.
