The Paracord Belt
Intro: The Paracord Belt
Today I will be showing you how to make this awsome belt out of paracord.
*Since this instructable is confusing try to follow the pictures, because what I can't put into words will be explained by the pictures.
STEP 1: Materials
For this instuctable you will need each of the following:
x1 a belt buckle
x2 32ft of paracord
x1 4.5ft of paracord
scisors
lighter
imagination
x1 a belt buckle
x2 32ft of paracord
scisors
lighter
imagination
STEP 2:
Take the middle of the shorter cord and fold it in half,and make a cow hitch around the middle of the buckle.
STEP 3:
take one of the other cords and make one side the same length as the other cord on the buckle and make a cow hitch, and repeat with the third cord so that there are three cow hitches in a row.
STEP 4:
take the cords and divide them in half, then take the right outer cord and loop it under the two inner cords. Then take the left outer most cord and loop it over and through the loop of the outer right cord, and tighten the cords.
STEP 5:
repeat the last step until the desired length or go onto the next step to make the belt look cooler.
STEP 6:
after repeating step 4 about 10 times I decided to change the pattern of the belt.
First what you do is you loop the right outer cord over the cords then take the left outer cord and loop it under and through the right cord. then reapeat step 4 once and reapeat this step again.
STEP 7:
once there is about 1-2 inches left start doing cobra braids until there is almost no moe core. cut and singe the core close enougth that the core won't go inside the belt but not so that it is sticking way out, and cut and singe the outerr cords so that the belt won't unravel.
STEP 8:
The end.
have fun making this belt, and please vote for me on the survival contest.
14 Comments
LukeRaley 5 years ago
it took forever but i made it
also what type of paracord did you use 425, 550, 650, or etc...
Marcaine Art 9 years ago
Cool! Do you have any formula for determining length so there is less waste or do you just kind of wing it?
i measured the small cord to fit my waist less waste
super pollo 9 years ago
I kind of winged it, but I only had about 6ft left over, but you can easily do something with the leftover.
hey so i understand the three cords but you should have put the the 4.5 feet cord is the length. you should edit it and say "fold the paracord in half then wrap it around your waist and cut it to the right size or make it the same length as a belt that fits you"
matthieu.tanchanco 9 years ago
Why do you need 4.5ft paracord for? Do you mean that 3 cords is 32ft each?
MetronomeMagic 8 years ago
The 4.5 ft of paracord is the paracord being wrapped; the center one. The 2 32' strands are the ones being wrapped around the center
Lilworm337 9 years ago
TheSurvivor99 9 years ago
It makes 4ft.
nperdomo 9 years ago
Maybe I will do it on leather..
zillmore 9 years ago
grrr21 10 years ago
Better belt tutorial than others I've seen - thanks!
