The Storm 220 V1.7 Knex Bolt Action Rifle.
17,393
32
346
Introduction: The Storm 220 V1.7 Knex Bolt Action Rifle.
About: Figured it was high time to give this a quick edit. I was an active part of the K'Nex community from about '08, I still occasionally lurk. I did a lot of dumb stuff on here but I'm past it now. I'm currently s…
This is my brand new knex gun, the storm 220. It was designed for mainly looks, but it functions well, and has decent range. I am not going to say be nice, even though this is my first Instructable, because I think people are entitled to their opinion. This gun shoots around
75 - 80 feet with the right rubber bands. It is not that good compared to guns like the SR-V1, or the osnjckma2, but I tried my best. I also apologize for some of the photos' poor quality, however you will probably be able to find your way around this.
VERSION HISTORY
V1.0: I was messing around with knex and made a cool looking shape for a gun. It was originally a pistol, and shot about 5 feet, and had a block trigger...
V1.1: I added a longer barrel and a front hand grip. It loosely resembled a UHC 870 shotgun (look it up!), still no trigger.
V1.2: I added a better firing mechanism, and it finally had a true trigger! (yay!)
V1.3: I remodelled the back of the gun to give it a flatter shape, and added a stock.
V1.4: I added a bottom loading removable clip which held 10 shots.
V1.5: The stock received a complete rebuild, making it stronger and making the entire gun look better.
V1.6: I replaced the magazine with the clip from the scar assault kit here, and the gun fires even farther.
V1.7 I remodelled the frame a bit, and decided to stop modding it from then on, and finally post it
FEATURES
True trigger
Removable 20 shot Magazine (scar 11.0)
Fires yellow rods
Rough sight
Strong stock
Feel free to post any mods you have.
I hope you guys like it; enjoy! :)
Step 1: Parts List, by Ksbf (again! :P)
parts list:
rods:
green:230
white:110
blue:50
yellow:4
gray:1
black:1
connectors:
dark gray:22
orange:56
lt gray:4
red:32
green:17
yellow:53
blue:56
purple:19
other:
tan clips:9
y clip:28
ball joint:4
Total: 698
Step 2: Handle and Trigger
Here you will learn to make the handle and trigger, just follow the pictures.
1. Build 2 of Piece A
2. Attach blue rods and Orange connectors
3. Build piece B
4. Slot blue rod into hole
5. Attach 2nd piece A to the handle, and you're done.
Step 3: Stock
This is the stock, again follow the pictures
1. Build the back side (lol) of Part A
2. Add this
3. And this
4. Make this
5. Attach them
6. Attach to what you have already built
7. Different view
8. Connect to handle
Step 4: The Main Body
This is the main body, it's pretty simple, just follow the pictures.
1. Build 2 of this, yes 2, you will need it later (mirror one of them) note the tan connector.
2. Connect to what you already have.
3. Connection different view
4. Add these parts
Step 5: Inner Workings
Here you will build the inner barrel, the mag well and the firing pin. Just follow the pictures.
1. Build the inner barrel.
2. Different view to step 1
3. Build the well
4. Different view step 3
5. Join them
6. Attach the inner barrel to the gap in the frame.
7. Attach well to frame
Step 6: Finishing the Body
Still got the other side? Good. Just follow the pictures.
1. Part needed.
2. Attach; you should be able to work it out
Step 7: Long Barrel and Foregrip
Here you will build the long barrel and hand grip (duh). Just follow the pictures.
1. Hand grip
2. Different view
3. Long barrel
4. Different view
5. Different View
6. Attach to gun
7. Add foregrip
Step 8: Elastic Bands
Add the elastic bands just follow the pictures.
1. Add firing pin to gun
2. Slide into here (note it is slotted into the grey rod)
3. Elastic bands; 1 short at least 1 long
4. Add one from here...
5. To here
6. Another Long one from here...
7. To here
8. Overview.
Step 9: The Clip
Here you will build the clip, vital for multiple shots.
1. Build these
2. Different View
3. Attach it together
4. Build the pusher
Step 10: Loading and Firing
To load, put 20 yellow rods in the mag and attach to the gun via the ball joint connectors. To fire, pull back the firing pin and pull the trigger. Repeat this process until the clip is empty, and then replace it or reload the old one.
Thanks for reading! Please feel free to post any mods you may have and I hope you have fun with the Storm 220 V1.7!
Jamalam
The Instructables Book Contest
Be the First to Share
    • Fix It Speed Challenge
    • New Year, New Skill Student Design Challenge
    • Jewelry Challenge
      Jewelry Challenge
    346 Comments
    2000smartkid
    2000smartkid
    9 years ago on Step 2
    does that orange connector have to be there? or can it be yellow?
    The Jamalam
    The Jamalam
    Reply 9 years ago on Step 2
    No it can be yellow, sorry I should have clarified :)
    2000smartkid
    2000smartkid
    10 years ago on Step 9
    where do you put the elastic bands for the clip?
    The Jamalam
    The Jamalam
    Reply 10 years ago on Step 9
    It's explained on a later step.
    The Jamalam
    The Jamalam
    Reply 11 years ago on Introduction
    That was ages ago... they're size 11 and naturally look odd now.
    deathbytoast
    deathbytoast
    good for you! give the little guys a hug for me =D
    2000smartkid
    2000smartkid
    10 years ago on Introduction
    dude that gun is SSSSSOOOOOOOOOOOOOOO awesome u rock (jk) (jk again)
    lowe
    lowe
    dont make this! mine only shot 5 feet
    The Jamalam
    The Jamalam
    Typical noob: blames the maker rather than questioning the likelihood of their own building fail.
    builder968
    builder968
    Reply 11 years ago on Step 5
    I just realized you were my first commenter!
