This Table Cost Pennies....literally
Intro: This Table Cost Pennies....literally
If you've ever wanted a new patio table for pennies, then this instructable is for you!
I was getting ready to throw away an old cheap glass-top patio end table when my wife came up with the idea of covering it in pennies. Since I really hate to ever throw anything away, it naturally seemed like a good idea.
STEP 1: Gather Your Supplies
I only needed a few things for this project. First, was an old, ugly table that happened to have a glass top.
Second, I used an adhesive that works on non-porous surfaces (I used Goop, but other similar adhesives should be fine).
Third, I didn't count them, but I probably used about $4 worth of pennies.
And finally, I used grout. I happened across a pre-colored bag of grout that was marked down substantially, so this worked for me.
I also used some cleaner to clean the table, a putty knife to spread the grout, and damp sponges and paper towels to apply and finish the grout.
STEP 2: Start Gluing
We started at the outside edge of the table to glue down the pennies. In our particular case we decided to do two rows of "heads," two rows of "tails", etc.
After gluing down all the pennies, we let the glue cure per the manufacturers recommendation.
STEP 3: Add the Grout
Once the glue had cured, we applied the grout. I mixed up a very small batch of grout, mixing it to a fairly stiff consistency. After mixing, I let it sit for about 20 minutes and mixed again to make sure all the dry ingredients were mixed well.
Since I was doing this part by myself, I wasn't able to photograph the process, but it was pretty simple. I placed a bit of the grout mixture on the table and forced it into every gap with a plastic putty knife. After covering all gaps, I then let it sit for about 20 minutes.
Next, I took a damp sponge and begin wiping the grout off the pennies, cleaning the sponge frequently as I progressed. After cleaning all the grout from the tops of the pennies. I wiped them down with a dry paper towel. All that was left was to let the grout cure overnight.
STEP 4: Let the Grout Cure
This turned out to be a relatively simple and inexpensive way to turn a cheap ugly table into a real conversation piece.
By the way, before anyone feels a need to tell me I violated federal laws by defacing coins, there's no need. No coins were defaced in any way (not cut, nor drilled, nor anything else). All the coins are still intact. No coin was harmed in the making of this table......
49 Comments
johndavidf 6 years ago
This appears to be a complete waste of time and money. I would rather roll up the coins and change each 100 to paper. I have over 10,000 pennies with which I am doing just that. Putting them on tables, bars and floors renders them practically useless. Just imagine the work in trying to recover them later.
JasmineO12 4 years ago
TereseD2 6 years ago
It cost the US tax payers 1.5 cents to make just 1 cent or "penny". Lets say it takes $10.00 in "pennies" to cover it. The actual cost for those "pennies" is $15.00. Add in the fact that you are permanently taking those "pennies" out of circulation and it will cost the US tax payers another $15.00 to replace those $10.00 worth of "pennies" brings the total cost to $30.00 for the initial manufacturing and replacement cost so you could have a "penny" table top. As a US tax payer I can't afford your "penny" table top!
Don H. 11 years ago
chandshar 11 years ago
coretj 11 years ago
bettyroug54 11 years ago
You people need to get a life. There is very little value in the metals used in coinage today. One would be hard pressed to even get face value for a coin; as they are no longer made from pure copper, silver and gold.
Knife141, I think your ible is great!
knife141 11 years ago
chocol4te 8 years ago
jangene1 11 years ago
tjones29 11 years ago
mochimaster 11 years ago
Would do a great design for a coffee table too!
Any table, really. In the backyard, in a cool hangout place in a garage or basement, you name it. I was thinking of using a whole combination of coins from around the world too for a table like that as well.
daylily 11 years ago
sup_b 11 years ago
mntbkrguy 11 years ago
I like the idea of different finishes, you can buy/make patina solutions to change the colors before or after the project is done, or just wait and see.
mosseltje 11 years ago
I'm gonna copy this some day:)
Since I'm from Europe, I'll do this with cents.
It might be cool to have 2 tabels, one in Euro's the other in Dollars :)
Question: Euro cents are made of copper, so they will turn green after a while, what about Pennies?
