Thor Spinner Fidget Toy
Intro: Thor Spinner Fidget Toy
Hey guys,
Here is my latest creation to be added and uploaded to the instructables gods. It's my Thor hammer inspired spinner fidget toy.
I have provided 2 tutorials on how to design and make it with Fusion 360 CAD-CAM, photos and files (STL & DXF) for you to either CNC machine in aluminium or 3D print at home. If you 3D print it stick some weights in holes in hammer end.
You will need 1 x 6001 bearing for your toy (sorry for the size, but I had these already at home).
Hope you enjoy it?
Cheers, Aaron
***Free A360 Files Download Here***
Aaron's CAD CAM Model: http://a360.co/2o15NXK
Aaron's F360 Demo: http://a360.co/2ntegWO
STL file: http://a360.co/2ntegWO
STEP 1: What You'll Need
Disclaimer: I do not take responsibility for the tool paths, feeds, and speeds outlined in the video or applied in the parametric models. Consult your user manual, supervisor and or teacher / CNC instructor before proceeding with CNC operations.
You will need the following:
-: 2 x pieces of 6061 aluminium 108mm x 95mm x 10mm (Length, width, thickness)
-: 1 x 6001 bearing i.d.12mm, o.d.28mm, width 8mm
-: 3 x 6mm x 20mm cap head bolts
-: access to a CNC milling machine and training if you're not a CNC operator
-: 1 x 10mm bolt with 2 x nyloc nuts (not required, but helps to hold the model)
-: alternatively you can download the files and just 3D print the model. Place the weights such as ball bearing or brass plugs in the 3 x 6mm holes in the hammer head for added weight.
STEP 2: Locate the YouTube CAD Video Tutorial
Click on the following YouTube video link which will outline how to design the model for yourself using Fusion 360.
STEP 3: Launch Fusion 360 & Start Designing
Launch Autodesk Fusion 360 and follow the detailed steps so you can design your own Thor spinner fidget toy.
STEP 4: Locate the CAM YouTube Video Tutorial
Open your internet browser and navigate to YouTube. Watch the detailed tutorial in order to CAM and CNC machine your own Thor spinner fidget toy.
STEP 5: Post Process & CNC Machine Op-1
Edit the tool paths in the CAM environment to suit your machines power and cutting tools speeds and feeds. Place raw aluminium stock in your vice or table. Post process your G and M code using the appropriate post and CNC machine operation 1. Note: make sure you set your G54 work offset in the proper location in all 3 axis (X, Y & Z).
STEP 6: Post Process & CNC Machine Op-2 Fixture Plate
Using the same processes that you did in the previous step. Insert you fixture plate into the machine vice or fix to your machining table and run operation 2. Do not remove from the vice or table. Tap all holes with a 6mm dia x 1mm pitch metric tap.
STEP 7: Post Process & CNC Machine Op-3
Bolt your original plate to your fixture plate. Post Process your code from Operation 3 and run your cycle. Remember to reset your Z-Height in your G54 work offset otherwise your run the risk of crashing your machine and or breaking your cutting tool.
STEP 8: Assemble and Play
1). Insert the bearing into the spinner
2). It may require a dob of bearing retaining loctite or superglue to keep it in place if loose.
3). Place some additional weights in the 3 x 6mm holes in the head of each hammer. You could use brass or ball bearings for this.
4). remove the seals from the bearing as these induce unnecessary drag and cause friction. Spray some WD40 or CRC periodically to lubricate if required.
6 Comments
AdamK242 6 years ago
can I buy one.
dctteacher1 6 years ago
Hello AdamK242, I don't have my CNC machine at the moment. When I get my new machine I can make you one ;-)
Hey Adam, sorry for my late reply but I didn't even notice this comment. I've recently sold my CNC machine at home and I'm waiting for my new machine to arrive. When it does I'll be happy to make and sell you one. Just pay for materials and shipping. Cheers Aaron.
liquidhandwash 7 years ago
Good one Aaron, my students have gone mad for these spinners too, I published a laser cut version for my year sevens.
dctteacher1 7 years ago
Hey mate how are you? It's really nice to hear from you. Thanks for the feedback I really appreciate it. Oh, your laser cut version is awesome. You do some really nice work and I hope your students appreciate it. Are you coming to the conference in May? If so lets catch up. Cheers Aaron.
Thanks Aaron, I havnt decided yet its a long drive from here, Ill let you know.
