Tie-down Clamps
Intro: Tie-down Clamps
Often, I can't find a clamp big enough to hold a project together while glue is drying or while I drive in some screws. Tie-downs are a good alternative, but can damage the edges of wood projects.
Additionally, there's often a great deal of friction when the webbing goes around a corner leading to uneven tension.
To fix this I made myself some tie-down clamps.
They are blocks of wood with rollers on the end. If you use cheap pine, they won't dent nicer hardwood when you clamp down on it.
STEP 1: Cut Out Pieces
I made these 15 inches long with 1.25 inch spacers from a 2x4 using a miter saw.
STEP 2: Connect Pieces
The hand drill was in use at another project, so I made the connections with biscuits and glue.
STEP 3: Square Edges
Square the edges with a miter saw, and sand smooth the surface you will place against your work.
STEP 4: Make/find Rollers
I've used skateboard wheels, plain bearings, and hardwood dowels. They all work about the same. A hardwood dowel piece is probably the easiest, especially if you have lathe (link to ifabricate description of a lathe).
STEP 5: Drill and Install Rods
Drill holes for the rods such that the rollers will not touch the ground. In my first set, the skateboard wheels extend beyond the 2x4. This is problematic because the clamps roll when you put a work piece on top of them.
I tried nails and bolts for the rods. Bolts are a bit easier.
13 Comments
monkeybutt777 8 years ago
I clicked on third picture down from the start and now I understand..... thanks guys
yea an instruction video would be great. I like the idea of tie down clamps. some times I don't have long enough clamps but I do have very long tie downs in my truck. what are the rollers for?
rimar2000 9 years ago
Clever idea. Maybe an explanatory video could improve this good instructable.
Advocat 14 years ago
They look like blocks of wood with wheels on (good for skating), and I don't see how you would tighten two of these to something. Any chance of a picture and an explanation?
Thank you in advance
ewilhelm 14 years ago
ArcoSU 16 years ago
Trent The Thief 18 years ago
GMoney1 16 years ago
crapflinger 17 years ago
Cristian Lavaque 18 years ago
sleepydog 18 years ago
gatonegro 18 years ago
thedarklordderfla 18 years ago
