Introduction: Tiny Cork Boat (Can Be Used for D&D)
This is a small boat made out of a cork. I made it because I needed a little boat figurine for my Dungeon & Dragons campaign.
- 1 wine cork
- 1 toothpick
- A knife
- A knife that can scoop
- Paper
- Safety pin
Step 1: Flattening One Side
Slice one side of the cork. You want to make it as flat as you can.
Step 2: Shape and Scoop
Next you want to shape the cork like a ship. The bottom of the cork will be the back of the ship. After that, you want to scoop out the inside of the boat using the scoop knife.
Step 3: The Mast of the Ship
Next you cut a toothpick as seen in the picture. Then you poke the bigger part of the toothpick in the ship. You may need to use safety pin to start a hole for the toothpick.
Step 4: The Other Part of the Toothpick
Now you take the shorter end of the toothpick and put it through the cork. Make sure to put it at an angle. You might need to use the safety pin to get a hole for the toothpick to go through.
Step 5: The Sail
Take a little piece of paper and poke holes through the ends of it with a toothpick it with a toothpick. Then slide the mast through the holes.
Reclaimed Materials Contest
