Introduction: Tiny TMNT Amigurumi Pattern
I made this little pattern for my friend's birthday. Forgive the bad pictures, I only had a cellphone handy.
Step 1: Mini TMNT Amigurumi Pattern
Step 2: Abbrevitions
st- stitch
MR- magic ring
sc- single crochet
inc- increase
dec- decrease
hdc- half double crochet
slt- slip stitch
blo- Back Loop Only
Step 3: Materials Needed
Green yarn- medium weight- 4mm- I use redheart soft touch because I'm a wimp and don’t like the feel of coarse yarn.
Small amount of blue/red/orange/purple yarn- depending on the turtle you’re making. Tan Yarn Brown yarn 3mm crochet hook Stuffing Yarn needle [to sew on parts and weave in ends.]
Step 4: Pattern
Head
[in green] r1. MR with 6
r2. Inc in each st around
r3. sc1, inc – repeat around
r4. sc2, inc – repeat around
r5. sc3, inc- repeat around
r6. sc around
r7. inc in next 4 st, sc in 22 st, inc in last 4
r8- r12. Sc around
r13. Sc4, dec- repeat around
r14. Sc3, dec- repeat around
r15. Sc2, dec- repeat around
r16. Sc, dec- repeat around
r17. Dec around.
Fasten off, stuff- keep in mind there will be a little bulge where the 'nose' is supposed to be. I shaped it even more by using a little bit of yarn and using this technique for where the eyes would be- http://amigurumiaskina.blogspot.co.il/2013/07/ami... I did this with the mask as well.
Bandana [in blue/red/orange/purple]
chain around 25- length depends on the size of the head, just make sure it fits around with enough room to tie in the back.
R1. Sc across. Fasten off. Place on head with enough room to tie in back of head, sew ends in and attach to head with stitches.
Shell- Back [in brown]
r1. MR with 6
r4.-6- sc around
r7. blo, 2 hdc in each stitch around. [creates the outer rim of the shell]
fasten off, weave in end.
Shell- Front [in tan]
r1. MR with 6
Fasten off, leave long tail for sewing. Sew back and front shell together, stuffing firmly just before closing it up completely.
Arms [make 2] [in green]
r1. MR with 6
r2-6. Sc around fasten off, stuff as needed, sew closed, sew to body.
Legs [make 2] [in green]
r1. MR with 6
r2. inc in each st around
r3. BLO- Sc around
r4. sc around
r5. sc1, dec- repeat around.
R6-8. Sc around.
Fasten off- stuff firmly, sew closed. Sew to body.
Belt [in brown] chain 15-20- enough to wrap around body and tie in front
I pulled my belt through the spaces in the shell rim and then sewed in the ends to keep it in place.
I hope this works out for everyone and I look forward to making more! I'd love to see pictures if anyone makes one!
