Toasty Slippers
Intro: Toasty Slippers
These slippers are made from recycled woolen blanket, recycled fleece fabric and scraps of brightly coloured fabric from my stash! I have a pair with red polka dot binding, they are so comfortable and keep my feet nice and warm.
STEP 1: The Pattern
This pattern will be available for download once i have worked out different sizings. The pattern has a seam allowance included.
As you can tell, this pair is for my friend Justine!
STEP 2: Cutting Out the Pattern Pieces
I will show you the steps for making one slipper, you will do the same for the second slipper but reversing everything, we don't want 2 left feet do we?!
You will need:
~an old woolen blanket, mine was found at the thrift store for around $5
~some warm recycled, i have used fleece also found at the thrift store
~ a scrap of colourful fabric big enough to make bias binding
From the woolen blanket cut 1 sole piece and 1 of each side piece.
From the fleece cut one sole piece.
You will need:
STEP 3: Sole
Pin the soles together and baste around the edge.
STEP 4: Slipper Top
Sew the top pieces together with a 1cm seam allowance then trim seam allowance and press open like you see in the photo.
STEP 5: Slipper Heel
Sew heel edges together with a 1cm seam allowance, trim the seam allowance and press open.
STEP 6: Sewing the Slipper Together
pin the slipper top to the slipper sole wrong sides together (so the fleece inner will be on the outside), using a 1cm seam allowance. Trim the seam allowance.
STEP 7: Turn
Turn the slipper right side out and press the seams. Trim the opening to your desired size, making sure you can fit your feet inside.
STEP 8: Cutting the Bias Binding
From your scrap of colourful fabric cut some strips on the bias. Mine are 3cm wide but you can make them wider if you like.
STEP 9: Fold Your Bias Binding
Fold your bias binding in half and press. Open up and fold one edge towards the centre, press again.
STEP 10: Attaching the Bias Binding-step 1
Pin the unfolded edge of the binding to the outside of the slipper. Sew around with a 5mm seam allowance. Trim the seam allowance.
STEP 11: Attaching the Bias Binding-step 2
Fold the binding to the inside of the slipper and pin. Slip stitch into place folding under the end of the binding to give a neat look.
Now make the other slipper in the same way but reversing the pattern.
STEP 12: All Finished!
The finished slippers. Now put them on and keep your feet toasty warm!
STEP 13: My Slippers
My slippers have red polka dot binding.
30 Comments
Jaina Solo 8 years ago
elizabeth.michelin 9 years ago
I look forward to the pattern. Great job. I am all for recycling/
JoyfullJuneBug 9 years ago
Super cute! I fond lots of patterns by image searching (DIY slipper patterns) I'm going to make some soon. Thanks =)
CrystalB01 10 years ago
so cool i want to make these now
Craftielady 11 years ago
kpaget 11 years ago
downunda_oz 11 years ago
wobbler 13 years ago
Thetis 12 years ago
But then you wouldn't get the funky seam down the front of the slipper for that great medieval look!
Teensy Doodles 12 years ago
ThePrintPlace 12 years ago
I've just published an instructable about how to turn an old wool jumper into slippers which you might find interesting. (not quite as stylish as yours though!).
https://www.instructables.com/id/Cosy-slippers-from-your-old-woolly-jumper/
dancing_sam 13 years ago
AnaLou 13 years ago
Great Instructable. Easy and fun! Very cool.
neverboredinportland 15 years ago
taraderuiter 15 years ago
cuteaznprincesss 15 years ago
Marysewfun 16 years ago
alvincredible 16 years ago
ccesclk 16 years ago
almostgotit 16 years ago
