Introduction: Toilet Paper Holder
Ever run out of toilet paper when you need it most? Well... I certainly do! Solution? The Toilet Paper Holder! They do sell these at home depot and I'm sure many other stores, but our goal is to save some cash isn't it? Make this handy toilet paper holder for less than $1!! That's right, less than $1! This is a very, very easy/simple DIY project. You may not have to spend any money at all if you have the right pieces (and tools) lying around the house.
Step 1: Materials You Will Need:
-.5 thick piece of wood(area big enough for toilet paper roll)
-cylinder shaped piece of wood (refer to photo)
-1 long screw
-drill bit
-screwdriver(hand, or electric)
possibly a saw(if you need to cut out the platform the right size)
-1 long screw
-drill bit
Step 2: Drill
Get out your drill bit and drill a hole right in the center(make sure it goes straight!) of the cylinder piece and one in the center of the platform as well. Doing each separately is much easier than trying to do both at once.
Step 3: Screw
Now use your screwdriver to screw the screw into the 2 holes made in order to connect them together. Note that the longer the screw, the better because the cylinder will have more durability/strength and will not wobble around.
Step 4: Finished!!
Fast, simple, reliable. Get the cylinder piece from Home Depot for 51c. Now you can avoid running out of toilet paper when you need it most! [-; Plus you'll always know when you're toilet paper is in stock.
