Tool-free, Custom Fit Shelves
Intro: Tool-free, Custom Fit Shelves
Easy closet shelving. No tools. No fasteners. Assembled in minutes. Disassembles even faster. Total cost: $48.00.
STEP 1: Only 2 Parts: Shelves...
The closet in question measure 22" deep, 64" wide. The doorway is only 47" wide.
So I went to the hardware store. I had them cut a plank of 3/4" plywood into 2 shelves measuring 22" x 64".
STEP 2: ...Spacers
I also had some 2x4's cut into 2' sections for use as spacers.
STEP 3: Clean Out the Closet
Take everything out of the closet.
STEP 4: Put in the Shelves
There's some molding running around the bottom of my closet, so I put down a couple 2x4's to protect the molding. Then I carefully put both shelves inside.
STEP 5:
Once both shelves were in, I muscled them up and put in the first set of spacers.
STEP 6:
Now you can erect the top shelf.
STEP 7: Profit.
Now you can put all your original junk back in plus a lot more.
2 Comments
bigjeff5 13 years ago
You also want to be sure there is something at the front of the shelving to keep the boards from being kicked forward and collapsing the shelf. Being a shallow closet yours works great going right up to the edge of the closet, but for a deeper closet deeper shelves become impractical, and you will either need to add something at the front to keep the supports from being knocked out, or simply attach the supports to the wall.
In that case a 1x2x2 piece of wood will replace a whole support.
slee15 13 years ago
