Introduction: Toothbrush Holder
I made a simple but very useful toothbrush holder.
To make this toothbrush holder you will need to use OnShape and go through the following steps I have provided. You will also need a 3D printer that fits you're needed size and price. You will also need filament in order to actually print the toothbrush holder.
Step 1: Make a Circle
You will create a sketch on the "top" plain and create a circle.
Step 2: Extrude Your Circle
You will then click the extrude button and adjust the measurements however you'd like.
Step 3: Create Another Circle
You will need to create another sketch on your extruded circle and then make another circle.
Step 4: Remove
You will now need to click extrude and look for the "remove" button and adjust the measurements where it will be deep enough to hold your toothbrushes but not deep enough to let the water go through.
Step 5: You're Done, Now Print
Now you're done and just need to slice it using a slicing software of your choice and then 3D print it!
