Toothpick Firing Pocket Crossbow (No Rubber Bands!!)
16,658
91
20
Introduction: Toothpick Firing Pocket Crossbow (No Rubber Bands!!)
I've recently built this little crossbow out of more things laying around at home. It's a smaller, and less powerful version of my other pocket crossbows posted here: https://www.instructables.com/id/Tension-pocket-crossbow-No-rubber-bands-or-cloth/
After building and playing with those, I decided I wanted something that could fire toothpicks. Not something that smashed my toothpicks to bits as they hit the wall. Something with less power, and something that won't have a high chance of breaking in my pocket. I've built plenty of Peg guns out of cloths pins, but I wanted a crossbow, and one that didn't use a rubber band as it's source of power. So, with my other crossbows in mind, I made some changes. The bow got smaller, I added some rigs to hold the crossbow together while in my pocket, I created a case, and I made it storeable. When in the case it's slightly larger than a tube of chap stick. But only so I know which one is my chap stick.
I am in NO WAY responsible for what you do if you decide to try and re-create what I have here! Keep it safe, don't point ANY fire arm (in this case crossbow) at ANY living creature! Unless it's a plant, or bug. Bug hunting can be quite fun.
As for the stock, it's made out of popsicle sticks, hot glue, pieces of paper clips, duct tape, and Q-tips.
The bow is made out of a steel blowdart with the sharp tip cut off, jewelers wire, and jewelers crimps.
I modded my bolts to contain steel tips, this added to the accuracy, and power. At far distances the tape on the ends of the bolts can cause the bolts to fail to maintain a straight trajectory. But what do you expect? They're tooth picks.
The case is made out of an old marker, cut into 3 pieces, taped together, and a wire around it to keep it closed.
As far as i've seen, this is the only real toothpick crossbow, and the only real pocket crossbow. All of the other "Pocket Crossbows" I've seen utilize rubber bands, and would crumple to pieces if you put it in your pocket. (I am of course not counting the one created by the jeweler, T. Shamir.) But, I could be wrong. I'm interested to see anything that doesn't use rubber bands and is small. So if you know of one, please post a link.
Be the First to Share
    • Teach With Tinkercad Contest
    • Cheese Challenge
      Cheese Challenge
    • Halloween Contest
      Halloween Contest
    20 Comments
    colt1005
    colt1005
    4 years ago
    How do make it
    Noodle Lord
    Noodle Lord
    5 years ago
    can you tell me how to make it? I want to know
    BatchDesigner
    i have a rubber band sniper that usually leave a huge welt from 5 feet away or less :P not a really good one
    buildit12
    buildit12
    7 years ago
    How do u make it
    Show the instructions please
    lamp3345
    lamp3345
    8 years ago
    Show trigger pleas
    Dom Toretto
    Dom Toretto
    9 years ago
    Whats the ible called an did u make it yet
    Geoffers
    Geoffers
    9 years ago
    how can I make on
    lglennon
    lglennon
    9 years ago
    Just show us howwww to make one
    Gentlemen...
    Gentlemen...
    9 years ago on Introduction
    Im making it, i get every thing EXCEPT the firing mechanism, Can you explain it? All other crossbows or slingbows ive seen uses clothespins, which obviously wont fit in this
    snowfalcon1
    snowfalcon1
    I have made a 25 foot SIAWF (Stick In A Wooden Fence) range crossbow that uses rubber bands AND won't crumple in pockets. Mission accomplished.
    Photo on 11-30-12 at 9.39 PM.jpgPhoto on 11-30-12 at 9.06 PM #2.jpgPhoto on 11-30-12 at 9.06 PM.jpgPhoto on 11-30-12 at 9.07 PM #2.jpgPhoto on 11-30-12 at 9.07 PM #3.jpg
    Slurpee801
    Slurpee801
    That's a great concept and all except... It's not a crossbow. A crossbow doesn't utilize rubber bands. That would be a slingshot shaped like a crossbow. You make it sound like mine will crumble in my pocket. Yet it's been months since I've crafted this and after said time in my pockets it still works flawlessly. Let me know how long that rubber band lasts. ;). Also, this wasn't built for power. It was designed to be portable and more to scale.
    snowfalcon1
    snowfalcon1
    i wasn't implying that yours would crumple, but you said that you hadn't seen any others that didn't. the bands do have to be replaced periodically, but it is sparse. i actually designed it after seeing yours and thinking ,"shoot- i don't have that kind of wire!" thanks for the inspiration.
    Snowfalcon Industries
    Dastan1996
    Dastan1996
    About an year ago, I made, for the same reasons (pocket/cool/non rubber band) a small (10cm) wooden (Half a clothespin) crossbow, which propels the darts through an iron hairpin and some nylon wire: I smoothed and curved the hairpin, then heated the central part, then I put it on the clohespin; for the trigger I used a pen clip (the internal part, the one you have to release by pressing on the pocket-clip).
    I guess the nylon wire didn't work out too well, since it recently broke... I'm not sure I explained myself, it's late and I'm writing on my tiny iPod virtual keyboard (I hate you, Apple), but I wanted to share my project: I loved yours! (maybe I'll post a couple of images in the next days)
    Slurpee801
    Slurpee801
    I'll have a how-to-ible as soon as I have time to make one. I've just been too busy to make another one of these.
