Introduction: Touch LED Table
This instructable is step by step how to build a touch led table
Step 1: Step 1: Get a Square Table
I used a small bedside table purchased from walmart
Step 2: Step 2: Cut a Hole in the Table
The next step was to cut a square hole in the top of the table and then I spray painted the entire table flat black. I also drilled a hold in the side of the table for the power cord to go later.
Step 3: Step 3: Ardino Code and Breadboard
I started with the following code and a push button with the setup shown to power the led strip.
CODE:
// This is a demonstration on how to use an input device to trigger changes on your neo pixels.
// You should wire a momentary push button to connect from ground to a digital IO pin. When you
// press the button it will change to a new pixel animation. Note that you need to press the
// button once to start the first animation!
#include
#define BUTTON_PIN 2 // Digital IO pin connected to the button. This will be
// driven with a pull-up resistor so the switch should
// pull the pin to ground momentarily. On a high -> low
// transition the button press logic will execute.
#define PIXEL_PIN 6 // Digital IO pin connected to the NeoPixels.
#define PIXEL_COUNT 30
// Parameter 1 = number of pixels in strip, neopixel stick has 8
// Parameter 2 = pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
// NEO_RGB Pixels are wired for RGB bitstream
// NEO_GRB Pixels are wired for GRB bitstream, correct for neopixel stick
// NEO_KHZ400 400 KHz bitstream (e.g. FLORA pixels)
// NEO_KHZ800 800 KHz bitstream (e.g. High Density LED strip), correct for neopixel stick
Adafruit_NeoPixel strip = Adafruit_NeoPixel(PIXEL_COUNT, PIXEL_PIN, NEO_GRB + NEO_KHZ800);
bool oldState = HIGH;
int showType = 0;
void setup() {
pinMode(BUTTON_PIN, INPUT_PULLUP);
strip.begin();
strip.show(); // Initialize all pixels to 'off'
void loop() {
// Get current button state.
bool newState = digitalRead(BUTTON_PIN);
// Check if state changed from high to low (button press).
if (newState == LOW && oldState == HIGH) {
// Short delay to debounce button.
delay(20);
// Check if button is still low after debounce.
if (newState == LOW) {
showType++;
if (showType > 10)
showType=0;
startShow(showType);
// Set the last button state to the old state.
oldState = newState;
void startShow(int i) {
switch(i){
case 0: colorWipe(strip.Color(0, 0, 0), 50); // Black/off
break;
case 1: colorWipe(strip.Color(255, 0, 0), 50); // Red
break;
case 2: colorWipe(strip.Color(255, 96, 0), 50); // orange
break;
case 3: colorWipe(strip.Color(255, 255, 0), 50); // yellow needs help
break;
case 4: colorWipe(strip.Color(0, 255, 0), 50); // green
break;
case 5: colorWipe(strip.Color(0, 0, 255), 50); // blue
break;
case 6: colorWipe(strip.Color(38, 222, 220), 50); // Teal
break;
case 7: colorWipe(strip.Color(75, 0, 13), 50); // Purple
break;
case 8: colorWipe(strip.Color(255, 0, 255), 50); // Pink
break;
case 9: colorWipe(strip.Color(252, 253, 253), 50); // white
break;
// Fill the dots one after the other with a color
void colorWipe(uint32_t c, uint8_t wait) {
for(uint16_t i=0; i
strip.setPixelColor(i, c);
strip.show();
delay(wait);
void rainbow(uint8_t wait) {
uint16_t i, j;
for(j=0; j<256; j++) {
for(i=0; i
strip.setPixelColor(i, Wheel((i+j) & 255));
strip.show();
delay(wait);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
WheelPos = 255 - WheelPos;
if(WheelPos < 85) {
return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
} else if(WheelPos < 170) {
WheelPos -= 85;
return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
} else {
WheelPos -= 170;
return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
Step 4: Step 4: Changing the Code
The next was modifying the code to account for the capacitive touch.
CODE:
#include #include
#define PIXEL_COUNT 30 int showType; Adafruit_NeoPixel strip = Adafruit_NeoPixel(PIXEL_COUNT, PIXEL_PIN, NEO_GRB + NEO_KHZ800); CapacitiveSensor tapper = CapacitiveSensor(2, 4);
void setup() { tapper.set_CS_AutocaL_Millis(0xFFFFFFFF); // turn off autocalibrate on channel 1 - just as an example Serial.begin(9600); strip.begin(); strip.show(); // Initialize all pixels to 'off
void loop() { long total1 = tapper.capacitiveSensor(30);
if (total1 >= 300) { if (showType > 9){ showType = 0; startShow(showType);} else { startShow(showType); showType++; } }
Serial.print("\t"); // tab character for debug window spacing Serial.print("\t"); Serial.print(total1); // print sensor output 1 Serial.print("\n");
switch (i) { case 0: colorWipe(strip.Color(0, 0, 0), 50); // Black/off break;
case 1: colorWipe(strip.Color(255, 0, 0), 50); // Red break;
case 2: colorWipe(strip.Color(255, 96, 0), 50); // orange break;
case 3: colorWipe(strip.Color(255, 255, 0), 50); // yellow needs help break;
case 4: colorWipe(strip.Color(0, 255, 0), 50); // green break;
case 5: colorWipe(strip.Color(0, 0, 255), 50); // blue break;
case 6: colorWipe(strip.Color(38, 222, 220), 50); // Teal break;
case 7: colorWipe(strip.Color(75, 0, 13), 50); // Purple break;
case 8: colorWipe(strip.Color(255, 0, 255), 50); // Pink break;
int lightCycle = 0;
// Fill the dots one after the other with a color void colorWipe(uint32_t c, uint8_t wait) { for (uint16_t i = 0; i < strip.numPixels(); i++) { strip.setPixelColor(i, c); strip.show(); delay(wait); } }
// Input a value 0 to 255 to get a color value. // The colours are a transition r - g - b - back to r. uint32_t Wheel(byte WheelPos) { WheelPos = 255 - WheelPos; if (WheelPos < 85) { return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3); } else if (WheelPos < 170) { WheelPos -= 85; return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3); } else { WheelPos -= 170; return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0); } }
Step 5: Step 5: Putting the Table Together
The next thing I did was put aluminum inside the cut out in the table, and then put a piece of plexiglass underneath and attached the capacitive touch wire to the aluminum and super glued the led strip on the inside of the table.
Step 6: Step 6: Finalizing
The last step was to put a mirror underneath the plexiglass and the led strip to help shine the light upward and then mounted both boards to a piece of wood and screwed it onto the bottom of the table.
Step 7: LED Touch Table
Final Code:
#include <CapacitiveSensor.h>
#include <Adafruit_Neopixel.h>
#define PIXEL_COUNT 28 int showType; Adafruit_NeoPixel strip = Adafruit_NeoPixel(PIXEL_COUNT, PIXEL_PIN, NEO_GRB + NEO_KHZ800); CapacitiveSensor tapper = CapacitiveSensor(2, 4);
if (total1 >= 2000) { if (showType > 9){ showType = 0; startShow(showType);} else { startShow(showType); showType++; } }
int lightCycle = 0;
Coded Creations
17 Discussions
3 years ago
Hey, Great work. I really like your project, I am working on a similar project and this is being a great help. The only problem I'm facing is that i can't really see your circuit cearly so if you could uplaod a circuit diagram that would be wonderful. Thanks :)
5 years ago on Introduction
Just a tip. When someone offers you constructive advice on how you could improve, at least thank them, and then consider it. Otherwise people will stop trying to help.
It looks amazing!
It would be very cool if it were an infinity mirror, but this design is quite good.
The video you shot doesn't do it justice because of two things: it was overexposed so I couldn't appreciate the colors well because they looked washed out. The advice is to go into your camera settings and turn down the exposure before shooting.The second thing is that you shot the video vertically, which phones should never allow you to do this, but they do. The consequences are that when you post it, it is turned sideways. However if the vertical video is posted with the correct orientation, you end up with too much space on either side of the frame. Always shoot horizontally. I'm sorry if I offended your videography, but this is a pet peeve of mine which prompts me to educate; you are not my first.
This is neat! Thanks for sharing.
I'm curious, what made you decide to make a touch LED table?
Reply 5 years ago on Introduction
It was for a school project
I can see something like this in my living room...or better yet my kids room. I never got school projects as good as this :-)
It was because she's awesome.
what makes it 'touch'? You activate it by touching the glass? Or how does that work?
The instructable doesn't go into very much detail about it, but it uses capacative touch via the aluminimum underneath and the capacative touch library code.
Check this out for more info:
http://playground.arduino.cc/Main/CapacitiveSensor?from=Main.CapSense
Thx for the info. Stumbled on that link just a few days ago when researching a capacitive touch sensor for a school project, thus my intrest :P
Great job there.
It was a pleasure working with you. Thank you for making my class awesome, best of luck.
Hello, what kind of led strip did you use ? Is the led strip 12 v ?
Greetings from Denmark
Gregor
Reply 5 years ago
I used a neopixel led strip from adafruit.com
Very nice work! Looks like your table turned out great.
Hey, welcome to instructables! :)
5 years ago
Very cool, great job
