Introduction: Touchscreen Internet Radio, Raspberry
Make this super easy and cool looking 2.8" touchscreen Internet Radio that can be controlled with PC, Smartphone and basically every machine that has got a browser and an internet connection..
(find the speakers at the back from here ;)
Components list:
-Raspberry Pi, basically any one works from the first gen.
-Cable between the screen and raspberry.
Case was printed with Printrbot Makers kit.
Step 1: Planning.
The dimensions in the picture are in millimeters.
The plan is simple. Make a table top case for the screen and raspberry. I had to make the base of the case 3mm taller than in the plans. I was fooled by the length of the solders under the raspberry.
The 3D model of the case was made with ScetchUp, witch is a free and brilliant software to use.
The project will include the printable file, but if you like and want to support my future projects you can buy the files from HERE. Cost is only 1 dollar and helps me a lot :)
Step 2: Printing.
The whole project is printed with Printrbot makers kit.
Simple and small printer does the job well.
Printing time for the whole case was about 2.5 Hour's. With layer height of 0.2mm and speed of 50mm/s. Nozzle size is 0.4mm.
Printed with support .
Step 3: Testing.
Test that the components fit in to case. In my case the parts just snapped in to place.
I had a Adafruit's plug and play image that works with the screen right away in the testing process. You can find the image from Adafruit's site under the PiTfT screen.
Remember to properly fold the cable in the case. If you like i have reserved a place for four buttons under the screen. I didn't have good (suitable) buttons to use in that place.
Step 4: The Rom.
I used a base of the Volumio image to use. It has got in basics a Web based Ui witch means that if you write your raspberry's IP address on your URL bar it will open a page where you can control the Raspberry.
To make the screen work i had to install the drivers to it and make the screen load up in boot. Then i had to install LXDE environment and finally make the raspberry's own internet browser to open up automatically with the Web Ui open.
Look on the next step to see how it is done.
Step 5: Install Drivers.
**NOTE**
The Volumio has to be version 1.41 to make the TFT screen work.
I will not guarantee this working in other versions of Volumio.
See volumio's page.
If you are going to use the Volumio without the TFT screen, just use the latest version available.
To connect to the Raspberry it has to be on internet. Access to it via SSH. Use PuTTy for easy access.
Basic username is : root
And password : volumio
1. Burn the Volumio image to your SD card. Find the instructions from the Volumio's site.
2. Remap the partition size. Add a line at a time to the console and answer the "questions" as follows.
<p>sudo fdisk /dev/mmcblk0<br>Command : d Partition number : 3 Command : n Select : default Partition number : 3 Partition start : default Partition end : default Command : w</p>sudo reboot
After reboot continue.
sudo resize2fs /dev/root
3.Get the drivers from Adafruit for the screen
sudo apt-get update
curl -SLs https://apt.adafruit.com/add | sudo bash
sudo apt-get install -y adafruit-pitft-helper
Wait the processes to finish and continue.
sudo nano /boot/config.txt
Insert this to the txt file.
[pi1]
device_tree=bcm2708-rpi-b-plus.dtb
[pi2]
device_tree=bcm2709-rpi-2-b.dtb
[all]
dtparam=spi=on
dtparam=i2c1=on
dtparam=i2c_arm=on
dtoverlay=pitft28r,rotate=90,speed=32000000,fps=20
Save the file with Ctrl+O and quit Ctrl+X
sudo reboot
After reboot the screen should be black. If it isn't redo the whole thing.
If the screen is black. continue.
Take the touch screen drivers to use.
write the command.
sudo nano /etc/modules
And add to the last line this.
stmpe-ts
Save and quit.
Last things to the touch screen are these.
sudo mkdir /etc/X11/xorg.conf.d
sudo nano /etc/X11/xorg.conf.d/99-calibration.conf
Write these lines to the screen and save.
Section "InputClass"
Identifier "calibration"
MatchProduct "stmpe-ts"
Option "Calibration" "3800 200 200 3800"
Option "SwapAxes" "1"
EndSection
Now the screen and drivers are installed. Don't worry. There is no picture at the time.
4.Next we will install LXDE environment.
sudo apt-get update
sudo apt-get install -y xserver-xorg xinit xserver-xorg-video-fbdev lxde lxde-common
This one is your "desktop".
5.Install and configure Chromium browser and LXDE
sudo apt-get install chromium x11-xserver-utils unclutter
sudo nano /etc/xdg/lxsession/LXDE/autostart
Insert the following lines to the autostart file. Comment (#) the screen saver line.
#@xscreensaver -no-splash
@xset s off @xset -dpms
@xset s noblank
@chromium --kiosk --incognito --user-data-dir --disable-touch-editing --enable-touch-events http://volumio.local
If you have a problem with the volumio.local address, change it to your raspberrys IP address.
finally write
sudo reboot
6. Now that everything is in order, Its time to wake up the screen.
Write
FRAMEBUFFER=/dev/fb1 startx
You should now have a picture in your screen.
To make it automatically to boot the screen on power up you will have to make a new file to boot it up.
sudo nano /etc/rc.local
Add these lines just before exit 0 line at the bottom.
sudo modprobe spi-bcm2708
sudo modprobe fbtft_device name=adafruits rotate=90
export FRAMEBUFFER=/dev/fb1
startx
save the file.
Reboot and hope for the best.
Step 6: Testing
See that everything works the way it should. Pop some speakers in to the plug at the back and hit play.
If you have any questions i will try to answer them as soon as i can.
Step 7: Bottom Lid.
Almost forgot. Glue the bottom lid to the bottom of the base. Use glue or tape or whatever.
If you want you can make a small "cut" to the base for the SD card for easy remove. You know...if you like to play Nes or other emulator with it ;)
Step 8: That's All Folks.
Thanks for reading. Enjoy your internet radio that you can control with everything that is connected to your local internet.
If you like my projects be sure to follow me to get the latest projects first.
And also remember to VOTE.
Happy buildings
-Miska Karvonen.
Runner Up in the
Mind for Design
3D Printing Contest
34 Comments
Question 5 years ago on Step 5
Hi, thanks for sharing this very cool project.
I have tried quite a few days to get this running now, but seems my skills in Linux are too limited to figure out what is not working.I got as far as editing the boot/config.txt. But after the reboot the screen is not black. And as per your instruction: "After reboot the screen should be black. If it isn't redo the whole thing."
I am just wondering from what section to redo? just the config.txt or start over with a new installation of Volumio?
After the reboot I am also getting errors similar to:
EXT4-fs (mmcblk0p3): initial error at time.... mb_free_blocks:1426: block 309248
EXT4-fs (mmcblk0p3): last error at time..... ext4_remount:4680
I did not manage to remap the partition size either, as when I attempted so, it would not boot up at all.....
But I reckon it should work without remapping the partition size?
Thanks for any suggestions, Bundi
6 years ago
Hi,
I have pi zero with Audio DAC hat, is it possible to attach a monitor/display, if yes how can I mount them together to pi zero? Thank you.
6 years ago
Finally I made it. After days (and nights) of trying, restart everything, trying again, my Raspberry music system works.
Everything worked as described, except for one thing: installing Chromium. All the sites I found with help for installing Chromium were already outdated. Finally I found the solution on this website:
http://kirsanov.net/post/2016/06/20/How-to-install...
Now, everything works flawless. Thank you mkarvonen for this tutorial. If you would see this message, then maybe you can change the way to install Chromium.
6 years ago
I was wondering if this could be done portable (with an integrated speaker and battery) and also with FM radio.
6 years ago
If I don't want to use your Pokemon speakers (they're awesome though) how would I go about connecting speakers to them that use RCA cables. To make things simpler can this play music through Bluetooth? I have this old stereo system that's great but behind with the times. I was thinking of adding a Bluetooth receiver to it and connecting it to this pie. So does this have Bluetooth functionality?
6 years ago
Hello
What changes if I use a 3.5" pitft screen?
Thanks
7 years ago
Is there a video of this bad boy in action?
8 years ago on Introduction
i think chromium-browser is now installed
thanks to this page
http://blog.valitov.me/2014/06/installing-google-c...
with some manual installations but now after all steps and the final reboot when i write
the screen does not turn on and i have to do CTRL+C to go out from the Xserver.
Any idea ?
Reply 7 years ago
I have the same problem!
I am using Pi2.
Before I managed to get LXPanel picture on my Adafruit, but later system somehow failed.
Is there some problem with chromium or what is it? My chromium version is 48.
HDMI-cable connected to TV it boots to LXPanel and it works fine.
I am not familiar linux at all so it is very difficult to solve this.
Any ideas? I really need this radio for my wife!
Reply 7 years ago
Ok, now I can get picture on my adafruit display.
It boots fine to the LXDE environment and I can use my mouse and keyboard to use it.
But I cant get chromium browser visible. When I use task manager to check if it's running, I can see that it is running on background.
I just cant make it visible. What is the problem here? Is it possible to use other browser to make this work?
"Package 'chromium-browser' has no installation candidate"
Hi, thank you for your tuto but i have this problem too, do tou have a solution ?
I have tried this :
sudo apt-get update
and then try the installation again.
sudo apt-get install chromium-browser
but it doesn't for me.
Thank you
8 years ago
It is possible right to change the OS to raspbian so it is like an ipad
Hi,
The OS is the internet radio itself. The picture in the screen is just a browser page opened in kiosk mode. This requires installation of the X in order to work.
By default there is no picture on the screen.
When I try to install Chromium, I get an error reading : "package 'chromium' has not installation candidate"
Do you have any thoughts on how to deal with this or another option for a browser?
Thanks,
Ryan
Hi!
If there are no installation candidates, try the command
sudo apt-get update
Hi,
Is the Volumio version 1.41 compatible with raspberry pi 2 model b?
I only get the rainbow screen on it after installing it on my SD-card and trying to boot it up.
If not are there any other options for me? :<
Thanks in advance
Reply 8 years ago
Hi. im not sure that this version of volumio works with raspi2. Did you remember to plug in Lan cable on the first boot? the volumio needs internet for the first boot.
Hi,
Yep just about everything was plugged in :< it worked with the latest image of volumio so im guessing the 1.41 version doesnt support raspi2.
That sucks tbh :< the interface looks so nice compared to the other options.
Thank you for the file link. After a few months I am getting back to this.
I have gone through step 3. I did the reboot but my screen does not turn black/go off it still remains on. I have started from the beginning 4 times but still the same result. I am using a B+.
What might I be doing incorrectly.
Hi, Do you have the exactly same type of screen that i am using?
If not, Try to look out for specific drivers for that screen.
Is the Volumio version 1.41?
If not, Try again with the correct version. This wont work with anything else.
When in terminal, try to hit the command FRAMEBUFFER=/dev/fb1 startx
to the raspberry, If the screen remains black or white repeat the driver installation.
(ie. No picture after a few minutes comes to the screen)
The screen is a picky one sometimes. Eventually it will work just keep it up!
Make a fresh image if you have the idea that something might be wrong.
