Introduction: Paracord Bracelet
Make a Paracord Bracelet with Tracer, a Tracer is a Piece of Micro Para cord braided along side. Adding a Tracer giving your Paracord Bracelet a unique look, and you can add another color to it. You can add a Tracer to any Cobra, or King Cobra braid. Note the Tracer will only show on one side. You can also use these instructions and make it without a Tracer. You can use a plastic side release buckle, or a metal adjustable buckle. The Paracord Supplies you will need:
+ 12 ft if Paracord
+ Paracord Buckle
+ 6 ft of Micro Paracord
+ Scissors
+ Lighter
Get a Paracord Bracelet kit.
+ 12 ft if Paracord
+ Paracord Buckle
+ Scissors
+ Lighter
Step 1: Paracord Bracelet - Step 1
Attach the Paracord to the buckles and then Mirco Para cord.
Step 2: Paracord Bracelet - Step 2
Bring the color of Paracord (that you want to be the center color) across the center. Then take the other piece of Paracord and the Micro Paracord over the top of the first piece of Paracord, behind the center and up through the hole make by the first piece of Paracord. Then pull it tight, keeping the Mirco Paracord in the middle.
Step 3: Paracord Bracelet - Step 3
Continue the same braid, Bring the first piece of Paracord across the top, take second piece of Paracord over the first, around the back, and up through the hole made by the first piece of Paracord. Then pull it tight.
Step 4: Paracord Bracelet - Step 4
Continue the same braid, Bring the first piece of Paracord across the top, take second piece of Paracord over the first, around the back, and up through the hole made by the first piece of Paracord. Then pull it tight. Keep braiding until you reach the other buckle.
Step 5: Paracord Bracelet- Step 5
Now cut and melt the ends, the shorter you can cut them the better. If you have a Para cord Needle you can run it back down the center to give it a cleaner look, the cut the Paracord tails.
Step 6: Paracord Bracelet - Finished
Here is what your Tracer Paracord Bracelet should look like, it may take a couple tries to get the braids tight. This is made with the cobra braid with a Micro Paracord Tracer. Sources How to make a Paracord Bracelet .com and 550 Paracord Projects.com. Get a Custom Paracord Bracelet.
