Introduction: Paracord Keychain Instructions
How to make a Tracer Paracord Keychain. I tried something new on this Paracord keychain, instead of stopping, and leaving a loop, I did the braid around it. I should of used the tracer on the other side, so it would show up on the outside more. Here are the things you will need to make a Paracord Keychain with a Tracer.
+ 3 ft of Paracord
+ 1.5 ft of Micro Paracord
+ Key ring
+ Scissors
+ Lighter
Made this, Learn How to make a Paracord Bracelet.
+ 3 ft of Paracord
+ Key ring
+ Scissors
+ Lighter
Step 1: Paracord Key Instructions - Step 1
Attach the Paracord and Micro Paracord to the Key ring, Make sure both tails of the Paracord are facing out, and the Micro Paracord is coming out of one of the pieces. You can make the length as long or short as you want the keychain. You can connect the 2 pieces of paracord by heating both end then squish them together.
Step 2: Paracord Key Instructions - Step 2
Lay one piece of Paracord across the top. Wrap the second piece of Paracord around the first then around the back and up through the hole made by the first piece of Paracord, and pull it tight. Keep the Tracer in the middle.
Step 3: Paracord Key Instructions - Step 3
Continue the Paracord Braid, Lay one piece of Paracord across the top. Wrap the second piece of Paracord around the first then around the back and up through the hole made by the first piece of Paracord, and pull it tight.
Step 4: Paracord Key Instructions - Step 4
Continue this pattern, Lay one piece of Paracord across the top. Wrap the second piece of Paracord around the first then around the back and up through the hole made by the first piece of Paracord. You can leave a loop at the end, or I tried something new this time..
Step 5: Paracord Key Instructions - Step 5
Pick one of the pieces of paracord your braiding and continue braiding just on one, and make it the top. This is were I messed up, as you can see the Tracer goes into the inside instead of outside.
Step 6: Paracord Key Instructions - Step 6
Continue braiding around it until you get back to the beginning, If you have a Paracord needle you can weave the ends back into the Keychain, otherwise you can just cut and melt the ends. Sources; 550 Paracord Projects.com, Paracord Keychain.com. Get Paracord Bracelet Instructions.
