Introduction: Transform a Plastic Organizer Into a Chic Artificial Succulent Hanging Garden
Hello everyone, I hope you're doing well. Today, I want to share a simple decor idea using a Dollar Tree plastic organizer. The organizer I'm using has three compartments.
We will be creating a hanging garden display with faux succulents. If you know me, then you know how much I love succulents.
Honestly, I could decorate every space in my home with them. The best part is that with artificial succulents, I won't have to worry about killing them. I'll provide you with all the details on creating your hanging garden display, and I'll include a full materials list below. Let's get started!
- One plastic organizer (I'm using the one with three compartments)
- Dollar Tree wallpaper sheet
- Wire
- Artificial succulents
- Hot glue
- Pencil or pen for tracing
- floral cutters
- scissors
Step 1: Tracing Onto the Wallpaper Sheet
Begin by placing your plastic organizer on top of the wallpaper sheet. Use a pencil to trace around the organizer, but don't worry if you don't trace every section. Remember, to make extra cuts when adding the wallpaper to each compartment.
Step 2: Cutting and Attaching Wallpaper Sections
Use scissors to cut out each traced section on the wallpaper sheet. Take each cut-out section and place it into the compartments. You may find that the sections are not perfect, but that's okay. Make any necessary cuts to ensure that they fit.
To add the wallpaper sections to the organizer, remove the backing from each one, exposing the sticky backing. Place each section into its compartment and press down gently.
Step 3: Adding Succulents and Wire
Now it's time to add the succulents to each compartment. Before adding them, use floral cutters to make any necessary cuts. Use hot glue to attach each succulent flower. If you prefer, insert a section of foam block in each compartment and add your succulent into the foam block.
Use your floral cutters to cut a section of wire. Attach the wire to the back of the organizer using a few extra wallpaper sections, clear tape, or hot glue.
Step 4:
Your succulent hanging garden display is complete! It's a great way to repurpose an everyday item and create a beautiful display of succulents.
Let me know if you try this project. I love hearing from all of you. Take care, and thank you for visiting!
Blog post--Transform a Plastic Organizer into a Chic Artificial Succulent Hanging Garden
Interested in more DIY craft posts? Check out my craft blog over at--https://stephcreatesthingsdiyhomeandcrafts.blogspot.com/
