Transform Your Oyster Travelcard With Sugru!
Intro: Transform Your Oyster Travelcard With Sugru!
We love our oyster cards in London. They are electronic ticketing RFID cards that make travelling around London so simple — just tap in and tap out on the tubes, buses, trams and even boats down The Thames! No more fumbling around for change to buy a ticket ever again, yay!
But we're a bunch of makers and hackers here at sugru, we like to tinker with things...
So the other day, Jude from team sugru (you'll probably know him as Hey Jude on Instructables), came in with a big grin on his face. This usually means one thing, he's been making something cool!
Well we were right, he had deconstructed an Oyster card and rebuilt it into a fully functional sugru Oyster key fob! (classic Jude). We thought it was so good that we've made a guide for the 'Ible community.
Tip: write down the card 'serial number' on the back before you dissolve it, that way you can still check your account information online.
NB — We're totally not the first to try this, we spotted Frank Swain's video from way back in 2008! But thought we'd give it a little sugru twist :)
STEP 1: What You'll Need for This Project
- an Oyster card
- nail varnish remover (acetone)
- latex gloves
- old cable flex (ours is salvaged from an old CD player)
- a glass chemistry beaker from the sugru lab (you could use a jam jar)
- a scalpel and cutting mat
- cling film (saran wrap)
- masking tape
- a piece of paper
- x2 5g minipacks of sugru (the colours are up to you!) — buy some sugru
STEP 2: Dissolve the Oyster Card in Acetone
- Pour the nail varnish (acetone) into non-plastic container. You'll need it about 1cm deep *
Top Tip: you'll want to use some latex gloves while handling the acetone.
- We stole this glass dish from the sugru lab (shhhh!), but you could always use a jam jar (might want to wash it first!). Just don't use anything plastic because the acetone will probably dissolve it!
- Leave the card submerged overnight (6-12 hours)
STEP 3: Remove the RFID Chip From the Dish
- After 6-12 hours, the card will be a mushy shadow of it's former self
- Look for the little black RFID chip
- Make sure that the RFID chip and antenna are totally free from the plastic card before removing it
Top Tip: Careful not to pull the RFID too hard, as it pretty fragile
STEP 4: Wash the RFID Chip
- Once you have removed the RFID chip and antenna, wash it in acetone again
- The rinse it carefully in water and dry off
Top Tip: You might want to let it air dry somewhere warm for 20mins
STEP 5: Time to Test the Configuration
- At this stage before going any further, we'd suggest you test that the RFID still works
- To test ours, we used masking tape to attach the chip and antenna to a piece of paper and folded it into our wallet (helps avoid getting any funny looks!)
- Then we jumped on the nearest bus to try it out... beep!
Top Tip: Instructables user xenobiologista4 told us about this free Android app that lets you test your RFID is working! :)
STEP 6: RFID Tested and Working? Time to Choose Your Sugru Colours
- For this project we matched the Oyster card colours - blue, cyan and white.
- If you want to mix things up, you can blend sugru colours to find the shade you want.
Top Tip: The sugru colour mixing chart will come in handy here
STEP 7: Cut Your Piece of Wire
- Choose the coloured wire you prefer and cut a strand about 10cm long. (this will be used for the tag)
- To get these wires, we travelled back in time to the 1990's to salvage them from an unwanted CD player ;)
STEP 8: Time to Make Your Sugru Fob
- This bit is really up to you, so get creative :) If you want to match the Oyster card colours, you can follow these instructions:
1. Mix 90% white sugru with 10% blue sugru to get a cyan colour
2. Roll the cyan sugru into a little sausage (we call it the 'Sausage of Cyan'!)
3. Roll out a flat piece of white sugru and wrap it around the cyan sausage
4. Roll out a second flat piece of blue sugru and wrap it around to make the outside layer.
5. Cut a little bit off the top and bottom of the sugru sausage (you can use these little bits for something else)
6. Cut the reminder in two, these will be your two halves (cut it quickly and confidently with a scalpel to avoid streaks)
(The panda version for Jude's wife – super cute!)
STEP 9: Adding the RFID and Antenna
- Flatten out the two halves between two pieces of cling film
- Add the RFID and antenna to one piece (try not to cross the wires too much)
- Add your wire to the other piece, to create the key fob loop
- Between two sheets of cling film, press the two halves together (with the RFID and wire are on the inside)
- Seal the edges of the two pieces of sugru to ensure a good bond
- Leave it to cure for 24 hours!
STEP 10: Now Go Show Off Your New Oyster Card... Beep!
As always, thanks for being part of the sugru community!
55 Comments
krmc 4 years ago
ajmir 9 years ago
this is illegal, the tfl ticket conductors (who are often looking to see if people have valid tickets) will fine you if you cause any damage to the oyster card. it happens all the time for people who cover it with stickers
jeremy.lambert.9047 9 years ago
They like to try but they can not fine you over this or even throw you from the train especially if the chip is topped up with the correct fare, it is merely a by-law which does not carry the force of Law and therefore can not be used against you.
robofw9 9 years ago
TfL conditions of carriage are here (just updated as cash is no longer accepted on buses): http://www.tfl.gov.uk/cdn/static/cms/documents/con...
These are by-laws. You are deemed to accept them automatically when you use a TfL service.
5.1 bans tampering "with in any way".
5.4 - 5.12 don't like changing any Oyster photocard;
6.1.4 emphasises Oystercards remain TfL property, "must not be
intentionally damaged, altered or tampered with in any way" and can be withdrawn or cancelled at any time.
There are regular manual checks and inspectors will want to see the card & its serial number to check against the online record.
So I suggest any creative reconstruction only be applied to plain vanilla Oystercards with small Pay as You Go credits No photocards, Zip cards, discounted cards, season tickets, nothing hard or slow to replace, nothing you absolutely depend for your day to day life.
However by-laws do not carry the force of Law so there is really nothing they can do even if they challange you they still can do nothing.
MatthewG1 9 years ago
While this process is undoubtedly cool, most transport concerns retain 'ownership' of the card and also are quite clear that you shouldn't tamper with it. So an inspector would be with in their rights to confiscate your modified Oyster (or what ever in your city) as it's quite clearly been tampered with. (Even though when they put 'tampering' in the conditions of use, what they meant was tampering with the data on the chip, not physical rebuilding the chip into something other than a card!)
The bracelet mod will probably work with a MiFare Classic based system, but the shorter reading distance of the newer more secure MiFare cards probably would prevent the pracelet mod from working reliably.
GeekTinker 9 years ago
I have always thought that their should be a way to integrate an RFID card into a cell phone case. 99.9 % of the time, I'm going to have my cell phone on me whenever I need to use the RFID card. I use an Otterbox for my phone and I just slipped the RFID card between the phone and the rubber case cover. Worked like a charm. Of course, now I work from home, so unless I install RFID activated locks, I won't be using it much.
LeeG 9 years ago
In reality I do not see why they don't issue a keyring version of the card anyway, there really is no need for them to be credit card sized. Then people could fashion removable Sugru sized covers.
keagz 9 years ago
I don't know why I can just use my smartphone as my Oyster card. They've already enabled contactless cards on buses so I don't see why they can't do the same for smartphones.
imccann1 9 years ago
I live in Tokyo and we have multiple RFID cards for transportation and the two most common cards are the PASMO card and the SUICA card. I have a PASMO card and have been using one for many years. I would really like to make this because it seems really cool, but in order to charge the card with money I have to feed it into a machine (like an ATM). I wouldn't be able to charge the card with this hack and I'm really disappointed :(
emmak 9 years ago
This is brilliant, my card has william and kate on it so its going in the acetone.
yamyams 9 years ago
emmak, if you've not yet done this project, would you be willing to trade your W&K card for a regular one?
Hey Jude 9 years ago
I have a Jubilee one too... sounds like we need a Top-Trumps of naff transit cards. (sorry Liz).
djsfantasi 9 years ago
Don't have Oyster in the States, but wouold this work with RFID fobs?
callum3343 9 years ago
Are there any particular brand of nail varnish remover thats particularly effective?
The one i tried striped the Oyster card into its three parts but didnt fully dissolve it
harryjoseph 9 years ago
Maybe I'm just a thick American, but once the deed is done, how do you periodically reload the new and improved Oyster with pounds for everyday, long-term use? I don't recall if there are non-LU shops that do that. Even if there are, wouldn't such a shop have a machine to feed the card into for the update?
digitig 9 years ago
You don't feed Oyster cards into a machine to reload them, you just touch them on a pad (or reload them via the Transport for London website, if you remembered to follow the instruction about writing your serial number down).
Dash_Merc 9 years ago
My only experience with RFID transit cards is in Chicago -- first with the ChicagoCard/Plus, and now with Ventra. For ChicagoCard and Ventra, you can just reload them at a kiosk or vending machine. For the ChicagoCard Plus and Ventra, you can reload them online through a web portal. As long as you register the card first, or make note of the numbers on the card before modifying it, you should still be able to use the online portal, and you should always be able to use the kiosks without issue.
Danger is my middle name 9 years ago
I'm American also but I've traveled on various public transportation systems all over the country and if they are RFID chip cards, you just boop them on the machine to reload them. In San Francisco where I live now you can add to it online too, although you would have to save the number of your card before you desolved it!
Mr_Moustache 9 years ago
Would this work for American Ventra cards?
