Transparent TENS Unit
12,759
29
9
Introduction: Transparent TENS Unit
This project’s aim was to produce a fully controllable TENS unit and a test bed for new concepts and patterns. TENS stands for Transcutaneous Electrical Nerve Stimulation. TENS units are used help relieve nerve related pain issues and relax muscles by chiropractors and physical therapist. TENS units produces a series of short, low current, high voltage pulses that pass through a portion of body and cause muscle contractions and varying sensations.
Most TENS units have preset patterns and some level of control; however, the aim here was to allow the user to generate there own custom pattern.
This TENS unit is built on an Arduino UNO, runs off a 9 volt battery, and just almost fits inside a translucent iTouch case. User interface includes an encoder that doubles as a push button and two additional buttons as well as a 16 X 2 character LCD display. The Arduino controls a dual channel 10 bit digital to analog converter to control the intensity of the pulses. The code on the Arduino manages the user interface while also controlling the timing of the electrical pulses which have timings ranging from 20 Hz to 150 Hz.
Additional features include a safety circuit that forces the system to reset if a pulse is generated that lasts longer then 700 us. As well as an attempt at a feed back circuit that could determine the load on the electrodes, this partially works, but has been shelved. The system can also be controlled by PC through USB. The button on top closest to the power switch toggles a standby mode that stops the electrical output to the user.
The user interface is very complete and allows many options. The display always shows the power of the Left and Right channel, below them it shows the range of 7 variables that can be cycled through. The encoder allows the user to cycle through 6 positions on the screen, then pressing the encoder down changes the cursor, and now the encode changes the value. The upper left position is mode, and the lower left position is variable such as pulse width, frequency, cycle time, and % of full power. Each variable has two values which become the two extremes of the wave mode selected.
The power side of the unit has not been refined enough yet, it does not have proper current limiting, but due to the size of the transformers, it does not saturate. However this causes some thermo effects, causing the output to drop, and lower power efficiencies.
Be the First to Share
    • Explore Science Challenge
    • Furniture Contest
      Furniture Contest
    9 Comments
    vvstubbs
    vvstubbs
    Question 11 months ago on Introduction
    Where is the circuit diagram and example code. Or did you NOT build this, if so don't post "to quote iceng" BOGUS articles. Thank you! (for nothing)
    ostaz0220
    ostaz0220
    1 year ago
    electronic diagram please ???
    iceng
    iceng
    3 years ago
    BOGUS
    Khaled G
    Khaled G
    4 years ago
    hey man i cannot download the pdf .. how can i get it ???
    KittlesBomb
    KittlesBomb
    6 years ago on Introduction
    Hi, there seems to be no instructions or parts list or code for this project. Has something gone wrong with the upload? Could we have it please?
    cageycruz
    cageycruz
    I didn't find any details either. Bought a membership just to get this one. But the PDF download has no schematic, no code listing, no pictures, nothing. Grrr!
    n3glv
    n3glv
    7 years ago on Introduction
    So where is the schematic? Parts list? Code for the Arduino?
    I ask for pdf and get not much more than shown here........
    alaboy
    alaboy
    Reply 6 years ago
    Did you get it?! I want it too..
