Treasures of Melting Ice
Intro: Treasures of Melting Ice
Learning to push yourself and trying new techniques and recipes are exhilarating parts of cooking. This recipe took a lot of experimenting, but it was so satisfying to finally nail it. I highly encourage you all to try this recipe. Delicious and a challenge!
Final components of the dish:
- Homemade ice sphere
- Vanilla panna cotta
- Strawberries
- Isomalt disc
- Mango spheres
STEP 1: Ice Sphere
Ingredients:
- Water balloon
- Water
- Lighter or blow torch
Instructions:
- Fill a water balloon with water (make sure it is big enough to fit your panna cotta glass)
- Tie the water balloon to keep it from leaking
- Place in the freezer for 6 hours (before taking it out, tap the outside to make sure it's frozen)
- Pop the balloon
- Use a lighter or blow torch to melt a hole in the side of the ice sculpture
- Pour all the water out
- Melt a hole in the wall of the sphere (based on how big your panna cotta glass is and what design you want)
- Keep in freezer until ready to present
STEP 2: Mango Spheres (part 1)
Ingredients:
- 1 chopped mango (or 3/4 cup mango pulp; both work but there's a slight color difference) - for the above picture I used chopped mango; for the final recipe presented, I used mango pulp
- 1/4 cup water
- 1/2 teaspoon calcium lactate gluconate
Instructions:
- Combine ingredients in a blender
- Blend well
- Pass mixture through sieve for smoother texture
- Pour mixture into molds
- Put in freezer until frozen solid (time: about 4 hours)
STEP 3: Mango Spheres (part 2)
Once the spheres are done freezing, prepare the sodium alginate bath and water bath
Ingredients:
- 4 cups of water (2 for sodium alginate bath; 2 for water bath)
- 2 grams of sodium alginate
Instructions:
- Add two grams of sodium alginate to 2 cups of water in a bowl
- Mix or blend to ensure the sodium alginate gets properly incorporated
- Set aside in fridge for 15 minutes
- Drop frozen mango spheres into sodium alginate bath; swirl them around in the liquid and let them sit for 3 minutes
- Then transfer the mango spheres into the water bath with a spoon; swirl around in water and let them sit for 3 minutes
STEP 4: Vanilla Panna Cotta
Ingredients:
- 5/4 cups milk (2% fat)
- 5/4 cups heavy cream
- 1 vanilla bean
- 1/4 cup sugar
- 2 teaspoons powdered gelatin
- 1/4 cup milk (2% fat); separate for the gelatin
Instructions:
- Add the powdered gelatin to 1/4 cup milk and keep it separate for later
- Add 5/4 cups milk, sugar, and vanilla bean to a pot
- Bring mixture to light simmer
- Take off the stove and add the milk gelatin mixture to the warm mixture
- Also add the heavy cream to the mixture
- Allow the mixture to sit for 20 minutes to infuse before placing in the molds/glasses
- Place the molds/glasses in the fridge
- Keep checking the panna cotta until the right consistency is achieved (solid but still springy)
STEP 5: Isomalt Disc
Ingredients:
- Isomalt
Instructions:
- Put circular mold/cookie cutter on a silicone baking mat (mold should be bigger than panna cotta mold/glass)
- Pour Isomalt into mold so it just barely covers the bottom
- Heat in the oven at 350 degrees Fahrenheit (for about 5 minutes; until melted)
- Take isomalt out of oven and allow to cool before removing molds
If you do not have a silicone mat (I did not), you can still heat the isomalt in oven on a baking tray or in a saute pan. However, be careful when trying to make a disc shape by hand! The melted isomalt is extremely hot, so please do not burn yourself when doing this.
STEP 6: Plating
- Chop strawberries into quarters and place on the panna cotta
- Place the isomalt disc on top of glass
- Place mango spheres on top of disc
- Add mint leaves to garnish
- Place whole dessert into ice sculpture
- Serve and enjoy!
2 Comments
Taimeterette 6 years ago
It looks amazing! Is it a lot different from the how to cook that with Mike Belcher recipe? (because then I most definitely have to try it)
https://youtu.be/TX9f31AUZvU?t=2m53s
aggarwalv3 6 years ago
Yep! It was my interpretation of the recipe. I wanted to change up some of the flavor profile to match what I like. Also, I wanted to figure out a simpler way to do the recipe so that anyone could make it without all the fancy equipment he had.
