Treat-dispensing Origami Cat Toy
Intro: Treat-dispensing Origami Cat Toy
This easy-to-make toy is based on the same principle as many other treat-dispensing toys. The large outer ball houses a smaller ball that holds the treat. With enough interaction, the treat will fall out, or your cat will tear the toy to shreds and access the treat. Either way, it's fun for you and your cat!
STEP 1: Materials
You will need:
- Two squares of paper, roughly in a 2:3 ratio to each other
- Scissors
- A cat treat
STEP 2: Make Two Origami Balloons
Fold two origami balloons, but don't inflate them just yet. If you're having trouble with the diagram, follow the link to its source where you can also watch an animation.
Diagram credit: Origami Club
STEP 3: Cut and Inflate the Balloons
Cut the open end off of both balloons, making sure that the small balloon can hold a cat treat (with enough room for it to roll out) and that the large balloon can hold the small balloon, preferably without so much room that it rolls out. As long as you have your mouth over the entire end, the balloons will still inflate normally.
STEP 4: Assemble the Toy
Place a treat in the smaller piece, then place the smaller piece hole-down into the larger piece. This ensures that the treat doesn't roll out right away. Now toss it and watch your cat play!
STEP 5: Reuse the Toy
You can reuse the toy if your cat hasn't destroyed it too much. Just pull out the inner piece and reload with a treat. You don't need to re-inflate the pieces with your mouth, you can just use your finger to pop them back into shape. Alternately, your cat might just like playing with the now-empty ball of paper.
8 Comments
Leopardjoy16 9 years ago
This looks tricky! But that's because I have never done origami, but I'll try this! I;m trying to play with my cat more because when i'm doing something, she BEGS to play! She walks up to me and sits down a feet or two away from me and stares
chuCraft 9 years ago
Kitten513 10 years ago
dneighbors 11 years ago
chuCraft 11 years ago
kitchentablescraps 12 years ago
scoochmaroo 12 years ago
ChrysN 12 years ago
