Triforce Chainmaille Pendant
Intro: Triforce Chainmaille Pendant
This is my first tutorial so it isn't the best but please bare with me :-)
As a lover of The Legend of Zelda it seemed only right to finally have a Triforce of my very own. I've found a lot of other LoZ fans I've met really like it too.
This pendant uses the helms weave and while it can be fiddly it is easy to pick up. Hope you like it!!
STEP 1: Materials
2x Chain Nose Pliers (or jump ring opener)
81x Large Jump rings (I don't have the size as these were a gift)
78x Small Jump rings
STEP 2: Start First Row
Connect four large jump rings together using two small jump rings between each one.
STEP 3: Captured Ring
Lay a large jump ring over the joining sets of two.
Thread another large jump ring through the joining sets above the captured ring.
STEP 4: Repeat Steps 2-3
Repeat above steps but instead make rows of three and two.
STEP 5: Connect Rows
Thread a small ring through all the pairs of large rings (not the captured ring), in all rows.
Once the other rows are connected add two large rings layered on top of each other to create the peak.
STEP 6: Repeat
Repeat steps 2 to 5 two more time so you have three triangles.
STEP 7: Connecting the Triangles
Once you have all the triangles made up attach one bottom corner to another using two small rings. This part can be fiddly but thread a captured large ring around the small rings and in between the large corner rings.
STEP 8: Finishing Up
Repeat step 7 two connect the tips of the base triangles to the bottom corners of the third/top triangle.
Finally add two small rings to the top of the upper triangle so you can attach it to a cord or a keying :-). You are now done!
4 Comments
Master97865 10 years ago
rofrix 10 years ago
ffcabral 10 years ago
rofrix 10 years ago
