Introduction: Trigger Smartphone Camera With Arduino
This tutorial shows you how to trigger a smartphone camera with an arduino every 2 seconds. You can modify this for your camera to trigger when
-a button is pressed
-motion detector is trigger
-receive a twitter tweet , etc
Step 1: Trigger a Smartphone Camera With an Arduino
Parts:
-breadboard
-jumper wires
-MCP4131 - 10K DIGITAL POTENTIOMETER ($3 CAD)
-arduino uno
-smartphone (any)
-TRRS Audio Jack ($2 CAD)
Step 2: Wire It Up and Solder TRRS Audio Jack
How the TRRS audio jack works:
The audio jack has 4 parts. -left -right -ground -mic
When the mic and ground are connected, it will trigger a smartphone. With a camera app, it will trigger the shutter button. Self-sticks use this.
If the mic and ground are connected directly, the shutter button will constantly be trigger. To fix this, a digital potentiometer is placed in between the mic and ground.
A digital potentiometer can electronically adjust resistance. When I want to take a picture, the digital potentiometer has 0 resistance. The connection between mic and ground is made. Camera triggers.
When I don't want to take a picture, the digital potentiometer has 10k resistance. The connection is blocked. no picture is taken.
TIP:
Before Soldering jumper wires to the audio jack. Plug in audio jack into phone with phone app on(link below). Physically connect the mic and ground with 1 jumper wire. The camera should trigger. Sometimes it works better to solder jumper wire on the outside tab on audio jack. Test where on ground and mic is best to trigger your phone before soldering.
Step 3: Code
#includebyte address = 0x00; int CS= 10;
void setup() { pinMode (CS, OUTPUT); SPI.begin(); } void loop() { digitalPotWrite(0); // no resistance here. Camera is triggered. delay(500); digitalPotWrite(128); //resistance here. Camera is not triggered. delay(2000); } int digitalPotWrite(int value) { digitalWrite(CS, LOW); SPI.transfer(address); SPI.transfer(value); digitalWrite(CS, HIGH); }
6 Comments
2 years ago
This works! Firstly, make sure you have the right audio jack - it must be a TRRS. Secondly, this is important and was my main issue (DonaldDu did mention it) - the connection can be terrible even when I'm touching my mic and ground wires together. My issue was that the mic wire wasn't making a strong enough connection - I ended up adding a bit more solder to ensure that the mic wire is making good contact with the outer casing of the jack. Lastly, the line '#include' needs to read '#include <SPI.h>" Cheers.
Question 2 years ago on Step 3
In the code , the #include shouldn´t have a file direction in it? Thanks a lot for the post, is going to be very useful.
2 years ago
wow, this was EXACTLY what I was looking for. Complete newb here.. I'll try it out with my iPhone
3 years ago
Would a relay work instead of the digital pot?
3 years ago
Hello,
I tried inserting the audio jack and manually connected the the GND and MIC wires, however even with the app running the shutter isn't activated. Can you tell me how I could trouble shoot this problem? Or, is there any other way I can trigger the camera using the Arduino?
Thanks
4 years ago
hi,
does this work?
has anyone got it working??
thanks
