Triple Pencil Case
Intro: Triple Pencil Case
Try to understand my bad explaining :/
STEP 1: What You Need
•fabrics
(At least one design of denim or canvas for the outside and whatever fabric you want for the lining)
•net pencil case
(You can probably make this easily but i already had one)
•zip
•fabric pens, buttons or anything you want to decorate it (optional) i used a pocket out from old jeans.
•sewing machine and needle and thread.
•net pencil case
•zip
STEP 2: Cut the Fabric
I drew the shapes that you need, 2 23x24cm squares for the lining, 2 23x14cm rectangles for the outside and 2 23x12cm rectangles for the inside.
STEP 3: Sew the Pockets
Put one 23x12cm rectangle and one 23x14cm right sides together and sew the bottom. Then fold one of the lining pieces around and sew the sides up.
STEP 4: Fold the Edges
Turn it the right way out and then fold over the edge of the short side. On the long side sew the lining onto the outside but leave the edge loose thats where you need to sew on the zip.
STEP 5: Zip
Sew the zip on the long edges that you left.
STEP 6: Middle Pocket
You have to hand sew this part. Use big stitches and thick thread to sew the middle pocket in between the other 2.
STEP 7: Zip
If your zips too long then sew it around like a handle.
STEP 8: Decorations
Sew/draw on whatever decorations you want
STEP 9: Done :)
I like pencil cases like this because you can have different pens in each section so they're easy to get out.
