Tumbling Portable Composter
Intro: Tumbling Portable Composter
I wanted to make a tumbling composter that was portable and super easy to make. Using sawhorses and ubolts allows me to move it anywhere. Took us about a hour to make and cost about $50 bucks!
STEP 1: Items Needed
One 55 gallon food grade barrel, 2 sawhorses, 2 ubolts, hinges, door latches. metal or wooden pole, a couple of cheap handles. You'll need a hole saw, drill and jigsaw.
STEP 2: Mark the Center of the Barrel
Mark the center of top and bottom. Then using a hole saw cut out a hole big enough for your pole to go through.
STEP 3:
Drill a random band of holes every 3 inches or so for ventilation
STEP 4:
Find the middle of the sawhorse and drill holes for the u-bolts.
STEP 5:
Cut out a door with a jigsaw. Use the hinges to reattach and the latches to keep the door closed when you spin.
STEP 6:
Place pole through the holes you cut and slip pole into the ubolts. We placed ours close to the garden so we can turn the door down and add directly to the garden or place a wheel barrow underneath the catch compost.
STEP 7: Feeding the Drum
Place your composting material in through the door. Lock it up and give it a spin. It does get heavy so handle placed randomly will help spin it.
STEP 8: Reap the Rewards
Keeps a garden healthy.
13 Comments
admin 15 years ago
AndrewKFletcher 14 years ago
niels70 12 years ago
I like your question except in my case, I have a tiny garden and no place to roll the drum to.
But an awesome question none the less.
Kindest
Niels
South Africa
Grafton 14 years ago
http://www.thenakedscientists.com/forum/index.php?topic=22494.0 My thermal solar panel :)
thesagedragon 14 years ago
dsandds2003 14 years ago
unbentcrayfish 14 years ago
surculus 14 years ago
Ninzerbean 14 years ago
mskittylitter 14 years ago
Taotaoba 14 years ago
