Turn Raspberry Pi Into a Network File System Version 4 (NFSv4) Server
Intro: Turn Raspberry Pi Into a Network File System Version 4 (NFSv4) Server
Network FIle System(NFS) can simultaneously run in version 2, 3, 4. NFS version 4(NFSv4) has several improvements over the NFSv2 and NFSv3. The improvements I like most are:
- NFSv4 makes configuring firewall simple because NFSv4 uses only one port (default to 2049) while NFSv2 and NFSv3 use 4 randomly changing ports
- NFSv4 provides strong security with the implementation of Kerberos while NFSv2 and NFSv3 don't
In my home network, all the computers are installed with Linux OS that supports NFSv4. Therefore, it is advantageous to configure NFS server to be ONLY operating in version 4 and disable NFSv2 and NFSv3.
After completing this instructable, you might be interested in learning how to use the automounter.
ScopeThis instructable will show:
- How to install NFSv4 server
- How to enable configure NFSv4 server
- How to disable NFSv2 and NFSv3
- How to run NFSv4 server
- How to test NFSv4 server
This instructable will NOT show:
- How to configure NFSv2 and NFSv3 server
- How to implement NFS client
- How to enable Kerberos
Linux rpipro 3.18.7+ #755 PREEMPT Thu Feb 12 17:14:31 GMT 2015 armv6l GNU/Linux
STEP 1: Install NFS
Open terminal emulator in Raspberry Pi
sudo apt-get update
sudo apt-get upgrade
sudo apt-get dist-upgrade
Install NFS
sudo apt-get install nfs-common nfs-kernel-server
STEP 2: Share a Directory
Make a directory to be shared
sudo mkdir -p /srv/nfs4/share
cd /srv/nfs4/share
Create a stub file or put any file in
sudo vi hello.txt
Type the following or whatever:
Hello NFS
Save the file
Add the above directory to be shared and exported
sudo vi /etc/exports
Append the following (192.168.CCC.DDD is the ip address of the client that can read and write to the shared directory):
/srv/nfs4/share 192.168.CCC.DDD(rw,sync,no_subtree_check)
Save the file
STEP 3: Modify NFS Init Scripts
The /etc/init.d/nfs-kernel-server script starts the NFS daemon in either NFSv2, NFSv3 and NFSv4 simultaneouly or without NFSv4. The script cannot make NFS operate in NFSv4 only. I modified the script to make it start the daemon in either NFSv2, NFSv3 and NFSv4 simultaneouly or without NFSv4 or NFSv4 only.
cd /etc/init.d
Make backup of nfs-kernel-server script and config file
sudo cp /etc/init.d/nfs-kernel-server /etc/init.d/nfs-kernel-server.pristine
sudo cp /etc/default/nfs-kernel-server /etc/default/nfs-kernel-server.pristine
Download the nfs-kernel-server.script that I uploaded
Read the script
Replace current script with downloaded one
sudo cp path/to/download/nfs-kernel-server.script /etc/init.d/nfs-kernel-server
Download the nfs-kernel-server.cfg that I uploaded
Read the config file
sudo cp path/to/download/nfs-kernel-server.cfg /etc/default/nfs-kernel-server
Make backup of nfs-common parameter file.
cd /etc/default
sudo cp nfs-common nfs-common.pristine
sudo vi nfs-common
Change:
NEED_STATD=
to:
NEED_STATD="no"
Change:
NEED_IDMAPD=
to:
NEED_IDMAPD="yes"
Save the file
STEP 4: Run the NFSv4 Daemon
Start the NFS service
sudo service nfs-kernel-server start
[ ok ] Exporting directories for NFS kernel daemon....
[....] Starting NFS kernel daemon: nfsdrpc.nfsd: writing fd to kernel failed: errno 111 (Connection refused)
rpc.nfsd: address family inet6 not supported by protocol TCP
rpc.nfsd: unable to set any sockets for nfsd failed!
Explanation:
The nfsd fail to start. This failure may not happen for some Raspberry Pi. inet6 refers to implementation ipv6 protocols. This issue can be fixed by loading ipv6 module Specify that ipv6 module is to be loaded at boot time
sudo vi /etc/modules
Append the following:
ipv6
Reboot the Raspberry Pi
Check that ipv6 module is loaded
lsmod | grep ipv6
ipv6 351566 8
Start the NFS service one more time
[....] Starting NFS kernel daemon: nfsdrpc.nfsd: Checking netconfig for visible protocols.
rpc.nfsd: Enabling inet udp.
rpc.nfsd: Enabling inet tcp.
rpc.nfsd: Enabling inet6 udp.
rpc.nfsd: Enabling inet6 tcp.
rpc.nfsd: knfsd is currently down
rpc.nfsd: Writing version string to kernel: -2 -3 +4
rpc.nfsd: Creating inet TCP socket.
rpc.nfsd: Creating inet UDP socket.
rpc.nfsd: Creating inet6 TCP socket.
rpc.nfsd: Creating inet6 UDP socket.
[ ok td.
Explanation:
The message "Writing version string to kernel: -2 -3 +4" is important. The minus sign indicates that NFSv2 and NFSv3 support is dropped. And the message at the end was OK. The NFSv4-only daemon has started!
STEP 5: Test With NFSv2, NFSv3 and NFSv4 Clients
Open terminal emulator in a second Raspberry Pi or any Linux system
Install NFS client software
sudo apt-get update
nfs-common package provides a program called /sbin/showmount. showmount show mount information for an NFS server by sending NFSv2 and NFSv3 request.
Use showmount to send NFSv3 request to the NFSv4 server deployed in the previous steps(#192.168.XXX.YYY is the IP address of the NFSv4 server)
showmount -e 192.166.XXX.YYY
clnt_create: RPC: Port mapper failure - Unable to receive: errno 111 (Connection refused)
Explanation: The error message indicates that the NFSv4 server did not respond to any request from NFSv2 and NFSv3 clients as expected.
Make NFSv4 client send mount request to NFSv4 (#192.168.XXX.YYY is the IP address of the NFSv4 server)
sudo mount.nfs4 192.168.XXX.YYY:/ /mnt
View the content of the hello.txt file that was created in the previous step
cat /mnt/srv/nfs4/share/hello.txt Hello NFS
9 Comments
Ring_Zero 2 years ago
ArkadiuszO 8 years ago
I make nfs server and client on two raspberry pi's 3 (raspbian jessie) when I made file (server side) on my shared place (/home/nfs) I can't see them on client side when I use x window file menager, but when I use terminal, go-> /home/nfs then "ls" I can see that the flie exist. From the other side, when I made file on client /home/nfs appear immediately on server /home/nfs. I'm using VNC to connect with both rpi's. Please help me figure out what can be wrong ? there is any chance that is issue with VNC ?
DmitryU2 8 years ago
When trying to install nfs-kernel-server on Wheezy on the RPI2 I've got an error:
The following packages have unmet dependencies:
nfs-kernel-server : Depends: libtirpc1 but it is not going to be installed
Depends: nfs-common (= 1:1.2.6-4) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
mirza irwan osman 8 years ago
Hi Dmitry
I have no problem such as yours on my RPI 2.
I did the following:
sudo apt-get update
Maybe you can try the above.
Best Regards.
I did all above but still have got:
libtirpc1 : Breaks: nfs-kernel-server (< 1:1.2.8-7) but 1:1.2.6-4 is to be installed
nfs-common : Breaks: nfs-kernel-server (< 1:1.2.8-6~) but 1:1.2.6-4 is to be installed
nfs-kernel-server : Depends: nfs-common (= 1:1.2.6-4) but 1:1.2.8-9 is to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
RobL57 8 years ago
enter this:
sudo apt-get -f install
AdamB142 8 years ago
I don't get any of the text output after sudo service nfs-kernel-server start. The cursor blinks for half a second and then I get the prompt back. No [ ok ] etc. Have I done something wrong?
NoelP12 8 years ago
Good info. Using Raspian Jessie, December 29, 2015. Found the changes to /etc/default/nfs-kernel-server had to be manually entered to make the nfs server work on start up. Neither NEED_STATD nor NEED_IDMAPD were in the new configuration file. nfs-kernel-server would start from the command line but would not start on boot up with out those changes. Thanks.
This issue reported here as well:
https://www.raspberrypi.org/forums/viewtopic.php?f=28&t=110091&p=822196
