Introduction: Turn Your Phone Into a GPS Using K'nex!
Imagine this: your lost in the wilderness on a lonely back road. You have no idea where you are and no way to find out. If only you had a way to find your way home! Luckily, you still have your cell phone and a box of K'nex in the trunk. It's time to make the (emergency) K'nex GPS/phone holder! This holder works for any rectangular device, such as the HTC EVO, iPhone, or Droid.* This can also be used as a dashcam to take video of any notable incidents while driving.
Step 1: Partz
You will need: 16 white connectors; 8 blue connectors; 11 yellow connectors; 10 grey connectors; 8 green connectors; 14 red connectors; 75 green rods; 52 white rods; 5 blue rods; 4 black caps; 5 blue separators; 4 grey separators; 6 blue caps; and 2 green bendy rods.
Step 2: Base
Build the base, which is shown here from two different angles.
Step 3: Back Support
Build these two pieces, then stack them. Next, add two white rods where shown.
Step 4: Add Back to Base
Add the back to the base as shown.
Step 5: Neck Piece
Build these pieces, and add them to the top of the back.
Step 6: Other Pieces
Build these two pieces and add them to the back as shown.
Step 7: Back of the Case
Build the back of the base, and add white rods. Next make two restraining beams and add them where shown.
Step 8: Blue Rods
Add two blue rods to the case. Add a grey separator and a blue cap to each blue rod on the front of the case (the side with the restraint beams). On the back side, add two blue separators and a grey separator to each blue rod.
Step 9: Swiveling Parts
Build this piece, and add a blue rod with a black cap as shown. Next, attach it to the case via the two side blue rods. Make sure the center white connector is facing outwards. Add black caps to the two blue rods on the sides.
Step 10: Attach to Base
Attach the case to the base by inserting the center blue rod on the case through the center hole in the neck piece. Next, add a blue separator and a black cap.
Step 11: Green Rods
Add a blue cap to each green rod. Next, insert it through the topmost red connectors on the case, and connect it where shown on the base.
Step 12: Rotating the Holder
To rotate the holder, take the blue caps on the green bendy rods off and pull the green rods out of the topmost red connectors. Then, rotate the case, and slide the green rods through the new topmost red connectors. Finally, put the blue caps back on the green rods.
Step 13: Done!!!
You now have and know how to use your K'nex GPS/phone stand! Thanks for viewing! Enjoy!!!
Step 14: NOTE
*I AM NOT AFFILIATED WITH ANY PHONE COMPANIES, TECHNOLOGY COMPANIES, OR K'NEX. NO COPYRIGHT INFRINGEMENT INTENDED. I AM NOT RESPONSIBLE FOR ANY PROBLEMS CAUSED BY THIS CREATION. PLEASE DRIVE SAFELY AND CHECK/FOLLOW ALL TRAFFIC/VEHICLE LAWS AND REGULATIONS FOR YOUR AREA. THANK YOU. :)
21 Comments
8 years ago on Introduction
If anyone builds this please post a picture!
X
My phone AND my GPS both do that a lot... :)
Nice!
Thanks!
Nice!
Thanks!
XD
Shut up you stupid GPS! "recalculating, recalculating!"
Nice idea and nicely executed; I can totally see why this was featured. Good job!
Thanks!
Awesome!
Thanks!
8 years ago
Look at my comments on my post, nerfrocketeer to see range on hydro mod
Ok
Oh my goodness!!! You featured!! Good job! I may make one of these for my dad's tom-tom.
Yaaaaaaaaaaaaaaaay!!! Thanks! =D
Awesome! Looks great!
Thanks so much for featuring it!!! :)
No problem - it looks amazing and your instructable was so detailed it's great!
Thanks!
