Introduction: Turn a Crappy Table Saw Into a Good One Up-dated
Hi If you viewed my Instructables on how to improve a crappy table saw you might want to further improve it by adding a removable router table. if you need any further information please check out the youtube video at the end of this sort intro.
Step 1: The Router Table Storage and Underside of Table
Parts required for the build assuming that you have built the side table so far.
2 tongue and grooved boards I used oak flooring
Glue
3 hardwood strips
NVR Switch with plug my is UK spec
Tools
Jig saw
power drill screw driver
I'm omitting the router lift if you need instructions for your build please look up Steve Ramsey youtube video.the only difference was that he used a round router and my was a plunge router that i butchered to fit
Step 2: Router Table Top Side
I glued the 2 boards together and routered a 10 mm rebate to the top after cutting the hole out with a jigsaw I used 10 mm nylon for the router lift top but and I re-enforced it with hardwood strips make sure that the strips are thin enough for the table to slide on past the table supports.
The router table slides on in the grooves
Step 3: The Router Lift
Router lift Curtsey of the Steve Ramsey Design
Step 4: Fence and Extraction
I used the fence and switch of my old metal router table, I don't use the router table that much but I'd like a £ for every time i moved it.
the top now sit permanently under my saw and the router lift lives under the Band saw stand,
I Have included a video link for all the steps outline above please view my other Video's and subscribe for more Machine improvements.
6 Comments
6 years ago
Hello, I'm gathering information before I start throwing money at work shop tools. I like the router and router table addition to the table saw. You mentioned having to butcher your punch router to make it fit. Can you tell what is needed, or would an edge router be more suitable?
Reply 6 years ago
first of all let me apologise for the late reply but somehowI missed your inquiry.
I didn't take any photos or videos of the router lift has its been done on utube by verious contributers. I had a small 3/8 plunge router that I used for the project I took the handles off and cut the pastic away on one side to form a round but on the otherside I kept most of the plastic on but ground it down to a flat 90 degree face and mounted this to the router lift with 2 jubilee clips.job done it took about 1/2 hour .in all the videos I've seen if using a round body router you have to make a carriage and clamps for it , I think mine was much easier to build once I got over having to take a hacksaw to it.
6 years ago
could you post a link to Steve Ramsay's video too?
Reply 6 years ago
Sorry I've just been on youtube and a I can't find a link but if you go om youtube and put in steve Ramsey with a E router lift it's in 2 parts hope this helps let me know how you get on
6 years ago
Subscribed. Thanks Marcello.
Reply 6 years ago
Thanks you, and thanks for the feedback
