Turn an Old Thermometer in a New One Using a Temparatur Sensor (DS18B20) and LED Stripe (WS2812B)
Intro: Turn an Old Thermometer in a New One Using a Temparatur Sensor (DS18B20) and LED Stripe (WS2812B)
I bought a nice old thermometer with an advertising for ice cream. This thermometer used a liquid scale for measuring the temperature. I turned this thermometer in a new one with an electronic temperature sensor (DS18B20) and a LED stripe (WS2812B) to display the temperature.
STEP 1: Preparing the Thermometer
The thermometer I used had a holder for the liquid scale. The scale was broken so you won't see them on the photos. If you have a thermometer with a liquid scale remove the liquid scale. I used this holder to fix my led stripe.
On the holder of the liquid scale you can mark the lowest and highest temperature as you see in the photos.
Remove the holder.
Fix the led stripe on the holder using a double-sided adhesive tape. You can cut the led stripe at the marked positions. The lenght of the led stripe depends on the distance between your highest an lowest temperatur. Be sure that there is a connector at the beginning of the stripe. The little arrows on the stripe show the sirection from inoput to output. Sometimes a stripe has two connectors - one at the beginning and one at the end!
Please count the number of led's your stripe has. In my case there were 68 leds.
I fixed the connector of the stripe additional using cable ties.
For the front I cut a piece of white acrylic glass, which I fixed in front of the LED stripe.
As a last step the acryl glass and the holder with the led stripe have to be fixed at the thermometer.
STEP 2: The Circuit and the Board
The circuit is very easy to understand. There are no special elements except the arduino and two resistor.
Circuit and board were designed with BlackBoard Circuit Designer (http://blackboard.serverpool.org), Version 1.1.3 Build 3.
For more information about the sensor DS18B20 and the led stripe WS2812B take a look at randomnerdtutorials.com
WS2812B: Guide for WS2812B Addressable RGB LED Strip with Arduino | Random Nerd Tutorials
The sensor DS18B20 has three connectors - power, GND and data. Data is connected to Pin GPIO 14 of the arduino. It is important that there is a pull up resistor (R2 = 4,7 kOhm) between power (3,3V) and the input (GPIO 14). Power is connected to 3,3 V and GND to GND.
The LED stripe WS2812B has also three connectors - power, GND and data. Data here is connected to Pin GPIO 13 of the arduino. A resistor has to placed between the output pin (GPIO 13) and the data pin of the stripe. Power is connected to 5 V and GND to GND.
For easier connection I used clamps.
First of all you have to interrrupt some strips at the bottom of the board. You can use a drill or a cutter. The picture of the botton of the board will show you where interruptions have to be placed.
As the next step you will have to place the wire bridges as you see in the picture. After that the two resistors have to be soldered.
Now you can soldering the clamps and the socket for the ardoino.
Put the arduino to socket and connect the sensor and the led stripe. Be careful of the correct cennection (power, data, GND).
STEP 3: The Arduino
Please look here for downloading and installing the arduino IDE: Software | Arduino
If this is the first time you use an arduino please add following URL to
FILE --> PREFERENCES --> Additional boards manager URLS:
https://raw.githubusercontent.com/espressif/arduino-esp32/gh-pages/package_esp32_index.json
Select the correct board (depending on the arduino you use)
TOOLS --> BOARD --> Select your board, e.g. "ESP 32 Dev Module"
Connect the arduino to your computer via USB
Select the correct USB-Port
TOOLS --> PORT: --> Select the port the arduino is connected to
Download the sketch and open the sketch in the arduino IDE:
FILE --> OPEN --> look for the downloaded sketch "Thermometer_LED.ino"
You will find the complete sketch on github: https://github.com/Adosis/Thermometer.git
If you have choosed the correct board and the correct port you can upload the code to the arduino.
STEP 4: The Sketch
At first three librarys were included:
#include <OneWire.h> // using more than one sensor at one port
#include <DallasTemperature.h> // library for using the DS18B20
#include <Adafruit_NeoPixel.h> // library for using the WS2812B-stripes
look here for the references:
DallasTemperature - Arduino Reference
Adafruit NeoPixel - Arduino Reference
The following lines are the parameters of your thermometer
float numLed = 68; // number of LEDs of your stripe
float lenThermo = 46; // the distance [cm] between lowest and highest temperature of your thermometer and also the lenght of your led stripe
float minTemp =(-10); // the lowest temperatur of your thermometer [°C]
float maxTemp = 40; // the highest temerature of your thermometer [°C]
The led stripe and also the sensor were initialized
// initialize the led stripe WS2812B
#define NUMPIXELS numLed
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, pinPixel, NEO_GRB + NEO_KHZ800);
// Setup a oneWire instance to communicate with any OneWire devices
OneWire oneWire(pinTempSens);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
In the setup routine the serial monitor will be set to 115200 and the sensor will be started
void setup()
Serial.begin(115200); // Start the Serial Monitor
sensors.begin(); // Start the DS18B20 sensor
In the loop routine the the data of the sensor are queried. I got the temperature in °C. If you want to have the information in F please change "temp = sensors.getTempCByIndex(0);" to "temp = sensors.getTempFByIndex(0)" .
As the next step all leds were turned off. To display the temperature the number of leds were calculated. There are two lines for calculating the correct led - depending where your led stripe starts. That means: shows your first led the highest or the lowest temperature?
The number of calculated leds were turned on. You can change the color of your leds in this line: pixels.setPixelColor(i,pixels.Color(255,0,0)) following the RGB-Code.
The loop starts again after 1000ms.
void loop()
sensors.requestTemperatures(); // preparing the temperature sensor
temp = sensors.getTempCByIndex(0); // get the temperature of the sensor in °C; please use sensors.getTempFByIndex(0) for temperature in Fahrenheit
// output on serial monitor
Serial.print(temp);
Serial.println("ºC");
for (int i =0; i<=numLed;i++) {pixels.setPixelColor(i,pixels.Color(0,0,0));} // turn of all LEDs
// example:
// -10°C is the lowest and 40°C is the highets temperature of the scale of the used thermometer
// the distance between -10°C and 40°C was 46cm
// the used WS1820 has 144 LED/m or 1.44 LED/cm
anzLed = round ((temp-minTemp)*((lenThermo/(maxTemp-minTemp))*1.44)); // calculate the number of LEDs to display the temperature
//use this line, if led 1 of your stripe shows the highest temperatur
for (int i = numLed; i>=numLed-anzLed;i--) {pixels.setPixelColor(i,pixels.Color(255,0,0));} // red
//use this line, if led 1 of your stripe shows the lowest temperatur
//for (int i = 0; i<=anzLed;i++) {pixels.setPixelColor(i,pixels.Color(255,0,0));} // red
pixels.show();
delay(1000);
