Turn Any Nut Into a Die
Intro: Turn Any Nut Into a Die
Use a triangular file to create a die out of any nut. A die is used to restore the threads on a bolt. You should carefully screw it onto and back off of the damaged threads, using a few drops of oil to lubricate. Remove the metal shavings.
9 Comments
enq 6 years ago
Do you think it can be used to thread a copper rod?
univegablack 1 year ago
Scepticxxx 7 years ago
sso in a pinch could I thread a steel rod with this?
benari26 8 years ago
can you show us some exampls of threaded dowels please?.
I tried that in the past on a 1" beech dowel soaked in linseed oil, it tears and crushes the fibers. A notced bolt will work as a tap but this one won't work as a die.
solomonhorses 12 years ago
jam BD 12 years ago
heathbar64 12 years ago
zazenergy 12 years ago
Fixit guy 12 years ago
