Turn Newspapers & Junk Mail Back Into Logs
Intro: Turn Newspapers & Junk Mail Back Into Logs
Disclaimer: According to the Seattle Times, in the state of Washington burning rolled paper logs is illegal. There may be other locations that also have laws regarding or prohibiting burning of news paper logs. While the Seattle times states that paper logs are bad for the environment, and makes reference to their own legislature, and a vague mention of the EPA, they do not cite any sources as reference. I am not here to argue their opinion, but having said this, it is upon you, that if you should decide to participate in the process of rolling your own logs to burn for whatever your reason, you should ensure that you will not run afoul with the local laws regarding what you can and cannot burn in your fire appliance. Whether it be an indoor fireplace or an outdoor fire pit, you should always fully educate yourself in any endeavor you take up to keep yourself and those around you safe.
This is the article for your perusal: http://community.seattletimes.nwsource.com/archive...
The purpose of this instructable is to educate you on the process of creating a paper log.
On to the project if you dare!
With today's focus on saving money, more people are turning to wood, pellet and corn stoves to heat their houses. What if instead of harassing the receiving dept's of companies with their own junk mail, or recycling your newspapers, you use them for inexpensive heating in your wood stove. Mind you I have no problem with recycling, but given the option of recycling, or keeping my family warm, I choose the later, hopefully you understand.
It's mid-spring right now, and it's the perfect time to start this project as it does take some time before the logs can be used in a wood stove for the winter. We use this method for camping every year, and it saves us the trouble of finding fire wood, or money by not having to buy precut pre-dried fire wood. The benefit is that it's virtually free, provided you value your time at zero.
STEP 1: What You Will Need:
Large container for water
Cotton string or twine
Water
And some spare time
STEP 2: Find the Perfect Spot to Setup Shop
STEP 3: Wet Your News Print/junk Mail
STEP 4: Drip Dry?
STEP 5: Roll It
STEP 6: Build It Bigger!
STEP 7: Rinse...Repeat...forever
STEP 8: Drying Time
I recommend standing the log on it's end to dry out, rather than laying it on its side.
Wet logs will not burn well, and tend to be smoky, so it's best to be sure to get them nice and dry before you use them. Setting them in a dry location that gets plenty of sun will help dry them faster.
STEP 9: Final Thoughts
A final note, I advise you be somewhat selective about the kind of paper you use. Some paper like those found in magazines are coated. If this paper is burned it tends to put out a thick black smoke. I don't know what it is that the paper is coated in, but I suspect it's something to do with plastic. This would be bad for the environment, so please recycle this kind of paper.
The best kind of paper to use would be newspapers, and credit card bills(after you've paid them of course)
Here is a shot of the log dried out. An unfortunate side effect is sometimes the paper log will grow a little mold on it while it's drying. This can be seen on the side of the roll. If this kind of thing bothers you, then you should probably stand the roll on a suspended wire mesh, or chicken wire so that it can dry without sitting in a puddle.
45 Comments
RaVenS17 6 years ago
I've seen camp stores or people make their own melted wax and sawdust to make fire starters. Thanks for the helpful tips and I just LOVE your sense of humor. :D
trailleadr 6 years ago
Thanks! Nice to see this 'ible is still getting some love.
C-Chip 7 years ago
People should be aware that paper logs are so harmful to health and the environment, that they are illegal in some places. This column from a Seattle paper describes why: "The reason burning compressed paper as fuel is illegal is because it contributes significantly to dangerous air pollution in your neighborhood.
Of eight fuel types rated by the Environmental Protection Agency, newspaper logs ranked third worst for particulates (tiny particles that float around in the air and cause big problems for asthmatics and others with respiratory conditions), and worst of all for carbon monoxide (a poisonous gas that causes problems for everyone). And although black ink burns fairly completely, toxic metals such as lead, chromium and cadmium commonly found in colored ink supplements can go up your chimney to redeposit in the neighborhood." http://community.seattletimes.nwsource.com/archiv...
Agonnazar 6 years ago
Must disagree. From the EPA itself, near the bottom of the page. The EPA recommends using newspaper logs.
https://www3.epa.gov/epahome/hi-winter.htm
No mention of it in the EPA's best burn practices
https://www.epa.gov/burnwise/burn-wise-best-burn-p...
RitaRibs 9 years ago
I have one of those log rolling devices around here, somewhere, but can't find it, OF COURSE! However, I do have a bucket of string and a ton of Elmers glue from a massive markdown one year of school supplies and a stack of newspapers ready for the recycling bins. I also have a very hot shed! I am going to make a set of paper logs with a bit of plastic covered twine, so I can hang it in the shed to dry and when its dried out, I will remove the plastic twine and move onto the next batch. My time, while not free, is mostly spent finding ways to make the best of what I've got for less or nothing. So far, I have a lifestyle of one making 100K for less than 10k per year. This ought to add a little fun in the chiminea project, and these can be mingled in with the free wood from neighbors felled trees, kindling and pine cones from the church across the street, as well as my own back yard. Neighborhood looks neater and no trees were harmed (well maybe the ones for the newspaper) but in my neighborhood, we rarely cut a good tree down. Its still making the best of what I have on hand!
C-Chip 7 years ago
Elmer's glue is a form of polyvinyl acetate (PVA), which should never be burned. It is basically like burning plastic and will emit toxic fumes.
cbaker6 8 years ago
if you have thge ability, leaving a hole in the center through the length so you can run a string, you could hang them on something like a clothesline or similar for it to get maximum air exposure.
pennysnunn 9 years ago
Roll pine cones up in the center of the paper roll* The oils in the pine cones make a HOT fire and give a little 'crackle' too!
zacker 11 years ago
trailleadr 11 years ago
The sting is just for holding the shape while it dries. They log in every case I've seen holds it's shape long after the string burns through.
zacker 9 years ago
cool... opps, I see I asked the same question about the string... lol
Striker_AC 9 years ago
My Grandfather used bailing wire instead of string. Easy to manipulate and holds no matter what happens to the log. His paper logs were typically minimum 6" rolls.
capnlatenight 9 years ago
I'd imagine the sawdust would create bumps which would make unsmooth layers, therefore trapping more water in and making it take longer to dry. You would have to put the sawdust in real smooth, thin layers. But don't take my word for it, I never tried it. Experiment, take risks, find out what's best.
zacker 9 years ago
Also, maybe standing it on one end for awhile and then flipping it and setting it on a dry area and let the opposite end dry a bit? how many newspapers would it take to make a whole cord of these? lol I think I may have that much saved at work(I collect all the newspapers people bring in to read!) lol does the roll unravel after the string burns away?
trailleadr 9 years ago
Every time I've done this the roll keeps its shape even after the string burns away or breaks. It will expand a little as it burns. If rolled tightly and completely dried it should hold it's shape quite well. Especially if you're using some form of glue.
You could probably dry out the logs in a dehydrator or an oven set to the lowest temperature. Maybe perhaps you can scent the logs by putting syrup, extract, or incense oils in the water.
vardamanj 14 years ago
I tried it, kind of. I had a spare bottle of Elmer's glue laying on my garage floor. I poured it in the bucket with water and paper just for shits and giggles. It made it smell good, and it held together a lot better than just water. I'd think it'd be too expensive to use glue and to just use water.
Zex_Suik 11 years ago
vardamanj 11 years ago
