Introduction: Turn Your Old Glass Into Beautiful Oil Lamp!
I've got some glasses from PEPSI or other drinks. I didn't use it because they are big and heavy.
So I decided to turn it into an amazing oil lamps!
You can make your own oil lamp pepsi glass with this instructable!
This instructable takes part in the contest JOBY, so rate it!
Let's get started!
Step 1: What Do We Need?
You will need :
-scissors
-Small ball
-thin foil
-cork
-lighter
-wick
-something to keep ball (look at the photo)
-curved thick wire
-Template to print
AND:
-vegetable oil
-PEPSI glass(or other glass)
-water(oh no! where can I get the water?:)
Step 2: Foil
Cut the foil to the shape of a triangle and put it on the cork.
IF YOU DON'T KNOW HOW MUCH BIGGER THE TRIANGLE MUST BE LOOK AT THE NEXT STEP!
Step 3: Making a Bubbles!
The triangle must fit to the holes in cork.
Heat up the ball with lighter and squeeze the bubble stencil, like my hands on picture.
The bubble in the middle of the triangle must be down
Step 4: Canals
You must make a canals for the oil like on the pictures.
Step 5: Wick
Cut the hole in the center bubble and put the wick in it.
Step 6: Glass
Fill the PEPSI glass with the water to 3/5 of the glass and the oil to 4/5
put the foil with wick on oil ant tap it with screwdiver and light the wick.
Step 7: Finish!
WE finish!
Enjoy with your beautiful swimming flame!
Thanks for reading please rate it if you like it!
BY kondzio29
Joby Transform It! Challenge
