Introduction: Tutorial on Making an Elegant Pearl Necklace for Wedding
Are you looking for a beautiful, dreamy pearl necklace for wedding? Here, I want to share with you this elegant pearl bead choker necklace made of white pearl beads and red faceted beads.
Step 1: Materials and Tools for Making This Handmade Pearl Necklace:
3MM White Pearl Acrylic Beads
6MM Red Bicone Glass Beads
3MM Light Golden Acrylic Beads
Tibetan Style Silver Toggle&Tbar
0.2MM Fishing Wires
Scissor
Step 2: Make the Side Part of the Necklace
1st, cut off a piece of very long 0.2mm fishing wire. Slide three pieces of 3mm white pearl acrylic beads, a Tibetan style silver toggle, other three 3mm white pearl acrylic beads, and a 3mm light golden acrylic bead onto the wire;
2nd, cross the wire through the light golden bead again to form a small beaded loop;
3rd, slide other three pieces of light golden acrylic beads onto the wire from the right hand side. Cross the left hand side of the wire through the last golden bead to form another small loop;
4th, make some knots with the wires and cut off one end. Slide 7 white pearl acrylic beads, a light golden acrylic bead, and other 7 white pearl acrylic beads onto the wire;
5th, cross the wire through the golden acrylic bead to form a loop, then cross the wire through more beads until it crosses through the new golden acrylic bead;
6th, in this way, continue to make two loops like the picture shows.
Step 3: Start to Make the Middle Part of the Necklace
1st, slide three golden acrylic beads, two white pearl acrylic beads, and three other golden acrylic beads onto the wire;
2nd, cross the wire through two white pearl acrylic beads like the picture shows. Then cross the wire through all the beads that are just slid on except the second golden acrylic bead and the fifth golden acrylic bead;
3rd, cross the wire through more beads until it crosses through the white pearl acrylic bead like the picture shows;
4th, slide 12 white pearl acrylic beads onto the wire, then cross the wire through the 5th, 6th, 8th, 10th, and the 12th beads again like the picture shows.
Step 4: Continue to Make the Middle Part of the Necklace
1st, cross the wire through some beads until it crosses through the white pearl acrylic bead on the far right of the pattern. Then slide 6 white pearl acrylic beads, 4 golden acrylic beads, a 6mm red bicone glass bead, and another golden acrylic bead onto the wire;
2nd, cross the wire back the red bicone bead then slide 3 golden acrylic beads onto the wire. Cross the wire through the white pearl acrylic bead to make a loop;
3rd, slide a new white pearl acrylic bead onto the wire, then cross the wire through five white pearl acrylic beads like the picture shows;
Step 5:
4th, cross the wire through some beads until it crosses through the white pearl acrylic bead on the far right of the pattern, then slide 7 white pearl acrylic beads onto the wire;
5th, alternatively cross these white pearl acrylic beads again like the picture shows;
6th, cross the wire through more beads then slide 13 white pearl acrylic beads and two golden acrylic beads onto the wire;
7th, cross the wire through one white pearl acrylic bead like the picture shows. Slide a new golden acrylic bead onto the wire, then cross the wire through the top golden acrylic bead;
Step 6:
8th, slide a red bicone bead and a golden acrylic bead onto the wire, then cross the wire back the red bicone bead;
9th, cross the wire through the golden acrylic bead then slide 5 white pearl acrylic beads onto the wire. Cross the wire through the top golden acrylic bead, then slide two new white pearl acrylic beads onto the wire;
10th, cross the wire through a white pearl acrylic bead and the next six beads like the picture shows;
11th, slide four white pearl acrylic beads onto the wire then cross the wire through two white pearl acrylic beads by the side. Cross the wire through more beads until it crosses through one white pearl acrylic bead on the far right of the pattern like the picture shows.
Step 7: Finish Making the Middle Part of the Necklace
1st, slide three golden acrylic beads, two white pearl acrylic beads, two golden acrylic beads, one red bicone bead and one golden acrylic bead onto the wire;
2nd, cross the wire through the red bicone bead again, then cross the wire through the below golden acrylic bead. Slide a new golden acrylic bead onto the wire;
3rd, cross the wire through 8 beads like the picture shows;
4th, cross the wire through more beads then imitate the former process to complete making the middle part of the necklace.
Step 8: Complete the Pearl Bead Choker Necklace
1st, finish the right side part of the necklace;
2nd, slide eight pearl acrylic beads onto the wire with a Tbar in the middle of them. Cross the wire through the golden acrylic bead to form a small loop. Make some knots with the wire, then cut off extra wires.
Step 9: This Is the Final Look of This Elegant Pearl Necklace.
Making this pearl bead choker necklace requires some patience, but with the help of this tutorial, it has become much simpler. And if you really like it, all the efforts you have devoted can pay off after you get this elegant pearl necklace. “No pain, no gain.” It certainly worth a try.
