Introduction: Arduino Tweetmas Tree * Updated With Code*
This year i want to decorate my house for Christmas.
I have arduino and led strip ws2811 ; what's all good !
It's need a good idea to be original ; it's with twitter !!
I heard about the cheerlights project; it's a good idea.
I'll make the Tweetmas tree !!
Step 1: The Skeleton
The first step is to make some (scratch) sketch !!
I choosen wood because it's easy and you can make mistake
I taken square wood section 25/25
The top angle is 90 ° and the over angle are 45 °
I put some pipe supports for the strip
Step 2: The Strip
It's neopixel strip with ws2811
I buy them on ebay , there is a very good seller it's jianzhou1984
He is very honest and he have very quick shipping from china to France.
I taken 3 meters and put them in a white flexi pipe .
Step 3: Cheerlights
Did you heard about Cheelights projects ?
First go to Cheerlights page
All is explained on the cherlights.com, you can change the collor of the world by tweeting a color .
To see the curent color : what's color is ?
To control the world !
How to control CheerLights
To control CheerLights, send a tweet to @cheerlights or include “cheerlights” somewhere in your message with the name of a color.
Example Tweet: @CheerLights Paint the town red
This will cause a chain reaction and all of the CheerLights controllers will change their color to red, since “red” is a supported keyword.
CheerLight Colors and Commands:
red
green
blue
cyan
white
warmwhite
purple
magenta
yellow
orange
pink (Added December 2013)
oldlace (Added January 2014 - same color as warmwhite, but it is now a standard HTML color name)
Step 4: Arduino
How to control Arduino ?
Cheerlights work with Thingspeak , there is a channel(1417) on Thingspeak.
You didn't need a Thingspeak account to send request to the sever !
You need :
BOM:
1 Arduino board
1 Ethernet shield Like this one
1 set of screw shield like this one
1 power supply 3A 5v
1 ethernet cable
One over favorite seller on Ebay is gc-supermarket
Step 5: The Code
Coding for me is a pain !!!
I shearched on the web working arduino sketch.
Lot's of them don't work but i find this guy on youtube:
He does a good job and give a good working code on his codebender :
I cooked his code with more patterns like : candy cane , Theatre style or rainbow wheel
This is my working code:
#include <SPI.h>
#include <Ethernet.h> #include <Adafruit_NeoPixel.h> // Local Network Settings byte mac[] = { 0xBC, 0x2D, 0x41, 0x70, 0x07, 0x98 }; // Must be unique on local network #define Brightness 5 //Set brightness to 5/10th // You can adjust brightness #define Full (255/Brightness) #define thingSpeakInterval 18000 // Time interval in milliseconds to get data from ThingSpeak (number of seconds * 1000 = interval) // Variable Setup long lastConnectionTime = 0; String lastCommandString = "black"; boolean lastConnected = false; int failedCounter = 0; Adafruit_NeoPixel strip = Adafruit_NeoPixel(167, 6, NEO_GRB + NEO_KHZ800); // For me 167 pixel on my strip // Initialize Arduino Ethernet Client EthernetClient client; void setup() { delay(100); // Setup Serial Serial.begin(9600); delay(100); Serial.flush(); delay(100); strip.begin(); strip.show(); // Start Ethernet on Arduino startEthernet(); } void loop() { // Process CheerLights Commands if(client.available() > 0) { delay(100); //Serial.println(client.available()); String response; char charIn; do { charIn = client.read(); // read a char from the buffer response += charIn; // append that char to the string response } while (client.available() > 0); //Serial.println(response.length()); Serial.println(response); if (response == "white" || response == "warmwhite" || response == "oldlace") { lastCommandString = "white"; theaterChaseRainbow(50); } else if (response == "black" || response == "off") { lastCommandString = "black"; theaterChase(strip.Color(0,0,0),50); } else if (response == "red") { lastCommandString = "red"; //theaterChase(strip.Color(255,0,0),50); CandyCane(30,8,50); } else if (response == "green") { lastCommandString = "green"; theaterChase(strip.Color(0, 255, 0), 50); } else if (response == "blue") { lastCommandString = "blue"; theaterChase(strip.Color(0,0,255),50); } else if (response == "cyan") { lastCommandString = "cyan"; theaterChase(strip.Color(0,255,255),50); } else if (response == "magenta") { lastCommandString = "magenta"; theaterChase(strip.Color(255,0,255),50); } else if (response == "yellow") { lastCommandString = "yellow"; theaterChase(strip.Color(255,255,0),50); } else if (response == "purple") { lastCommandString = "purple"; theaterChase(strip.Color(102,51,204),50); } else if (response == "orange") { lastCommandString = "orange"; theaterChase(strip.Color(255,153,0),50); theaterChase(strip.Color(0, 255, 0), 50); } else if (response == "pink") { lastCommandString = "pink"; theaterChase(strip.Color(255,53,153),50); } delay(200); Serial.print("CheerLight Command Received: "); Serial.println(lastCommandString); delay(200); } // Disconnect from ThingSpeak if (!client.connected() && lastConnected) { Serial.println("...disconnected"); client.stop(); } // Subscribe to ThingSpeak Channel and Field if(!client.connected() && (millis() - lastConnectionTime > thingSpeakInterval)) {subscribeToThingSpeak(); } checkcolor(lastCommandString); delay(500); // Check if Arduino Ethernet needs to be restarted if (failedCounter > 3 ) {startEthernet();} lastConnected = client.connected(); delay(100); } // End loop void subscribeToThingSpeak() { if (client.connect("api.thingspeak.com", 80)) { Serial.println("Connecting to ThingSpeak..."); failedCounter = 0; Serial.println("Sending Request"); client.println("GET /channels/1417/field/1/last.txt"); client.println(); lastConnectionTime = millis(); } else { failedCounter++; Serial.println("Connection to ThingSpeak Failed ("+String(failedCounter, DEC)+")"); Serial.println(); lastConnectionTime = millis(); } } void startEthernet() { client.stop(); Serial.println("Connecting Arduino to network..."); Serial.println(); delay(1000); // Connect to network amd obtain an IP address using DHCP if (Ethernet.begin(mac) == 0) { Serial.println("DHCP Failed, reset Arduino to try again"); Serial.println(); } else { Serial.println("Arduino connected to network using DHCP"); Serial.println(); } delay(1000); } // Fill the dots one after the other with a color void colorWipe(uint32_t c, uint8_t wait) { for(uint16_t i=0; i } //Theatre-style crawling lights. void theaterChase(uint32_t c, uint8_t wait) { for (int j=0; j<36; j++) { //do 36 cycles of chasing for (int q=0; q < 3; q++) { for (int i=0; i < strip.numPixels(); i=i+3) { strip.setPixelColor(i+q, c); //turn every third pixel on } strip.show(); delay(wait); for (int i=0; i < strip.numPixels(); i=i+3) { strip.setPixelColor(i+q, 0); //turn every third pixel off } } } } //Theatre-style crawling lights with rainbow effect void theaterChaseRainbow(uint8_t wait) { for (int j=0; j < 256; j++) { // cycle all 256 colors in the wheel for (int q=0; q < 3; q++) { for (int i=0; i < strip.numPixels(); i=i+3) { strip.setPixelColor(i+q, Wheel( (i+j) % 255)); //turn every third pixel on } strip.show(); delay(wait); for (int i=0; i < strip.numPixels(); i=i+3) { strip.setPixelColor(i+q, 0); //turn every third pixel off } } } } // rainbow wheel void rainbowCycle(uint8_t wait) { int i, j; for (j=0; j < 256 * 5; j++) { // 5 cycles of all 25 colors in the wheel for (i=0; i < strip.numPixels(); i++) { strip.setPixelColor(i, Wheel( ((i * 256 / strip.numPixels()) + j) % 256) ); } strip.show(); // write all the pixels out delay(wait); } } void rainbow(uint8_t wait) { int i, j; for (j=0; j < 256; j++) { // 3 cycles of all 256 colors in the wheel for (i=0; i < strip.numPixels(); i++) { strip.setPixelColor(i, Wheel( (i + j) % 255)); } strip.show(); // write all the pixels out delay(wait); } } /* Helper functions */ // Create a 24 bit color value from R,G,B uint32_t Color(byte r, byte g, byte b) { uint32_t c; c = r; c <<= 8; c |= g; c <<= 8; c |= b; return c; } //Input a value 0 to 255 to get a color value. //The colours are a transition r - g -b - back to r uint32_t Wheel(byte WheelPos) { if (WheelPos < 85) { return Color(WheelPos * 3, 255 - WheelPos * 3, 0); } else if (WheelPos < 170) { WheelPos -= 85; return Color(255 - WheelPos * 3, 0, WheelPos * 3); } else { WheelPos -= 170; return Color(0, WheelPos * 3, 255 - WheelPos * 3); } } void checkcolor(String colors) { if (colors == "white") { theaterChaseRainbow(50); } else if (colors == "black") { theaterChase(strip.Color(0,0,0),50); } else if (colors == "red") { //theaterChase(strip.Color(255,0,0),50); CandyCane(30,8,50); //30 sets, 8 pixels wide, 50us delay } else if (colors == "green") { theaterChase(strip.Color(0, 255, 0), 50); } else if (colors == "blue") { theaterChase(strip.Color(0,0,255),50); } else if (colors == "cyan") { theaterChase(strip.Color(0,255,255),50); } else if (colors == "magenta") { theaterChase(strip.Color(255,0,255),50); } else if (colors == "yellow") { theaterChase(strip.Color(255,255,0),50); } else if (colors == "purple") { theaterChase(strip.Color(102,51,204),50); } else if (colors == "orange") { theaterChase(strip.Color(255,153,0),50); theaterChase(strip.Color(0, 255, 0), 50); } else if (colors == "pink") { theaterChase(strip.Color(255,53,153),50); } }
Step 6: Videos
soon over videos!!
Make it Glow!
7 Comments
5 years ago
Where is the Candy Cane function? I see several calls, but not the actual function?
Reply 5 years ago
hi my friend
the candy cane paterne is with the red color
7 years ago
totof60 - I got a new Cheerlight project for this year - I did change the code slightly, it's pretty much the same, but thought you might be interested in seeing my lightsaber cheerlight.
https://youtu.be/Ox1UNJYxRN0
7 years ago on Introduction
Great display ..
8 years ago on Introduction
Very neat project, better then mine :-) I like your patterns too.
So, it's time to put them to work for me LOL
Marry Tweetmas!
big thanks for your comment
this project never born without your code. thanks for your help.
if you like you can vote for me in the contest !!
