Introduction: Two Stroke Carbon Buildup Removal.
Older two stroke engines tend to accumulate oily carbon (crud) in the exhaust. With the appropriate level of heat it can be cleared and power restored.
21,871
9 Comments
10 years ago on Introduction
i use a wood fire i threw my bike exhaust in a bonfire worked well
12 years ago on Introduction
I had a good result by spraying PB Blaster into the exhaust port. Engine off, and cold, spark plug out. Let stand for 30 minutes. Then I cranked the bugger about 20 times and got crud form spark hole and exhaust.
14 years ago on Introduction
Just a hint: heat will RUIN crome so don't try this on a chrome exhaust. Brake cleaner cleans out an exhaust pretty well.
i use a product called CERAMALUBE ENGINE TUNE-UP. it comes in a aerosol can and is sprayed directly into the throttle body. 1/2 can sprayed while someone is holding 1 or 2 grande behind the wheel (depriving the engine of oxygen will kill it) and then the other half 15 or so minutes later. smoke and black stuff (carbon) starts bellowing out during the spraying of the 2nd half of the can...pretty cool stuff...some guy invented it in holland where emission laws are more strict.
15 years ago
Many used grills hit the landfill every year, so finding a salvage grill is not to hard and the cost of propane is around $5.00 for the time required. I tried the torch method first and it smoked like crazy and took an incredible amount of time to get partial results. Photos are forthcoming. I need to reduce the resolution. This posting is about 50 percent humor, though the project was a complete success.
Reply 15 years ago on Introduction
Why do you need to reduce the resolution? Are you using dialup and afraid uploading the full-size pics would take too long? Seeing how this is your first Instructable, you may be worried about the page taking too long to load for your viewers. Don't worry about it, Instructables automatically resizes the pictures, while still making the full-size pics available for download. I apologize if you were already aware of this.
I resent this Instructable. It is an attack on my both my character and personal hygiene! You can believe me when I say I'll never read anything of yours again, carbon hater!
15 years ago
Actually instead of risking damage to an expensive grill and introducing a new "flavor" to it, just go get a propane torch and fire the exhaust manifold after removing it from the engine. Get the outside to a decent shade of red, and then finally put the torch down the throat of the manifold on the engine side to burn the baffle-plate clean. Or just soak it in brake cleaner for a few hours....
16 years ago
got any pictures? seems a little ineffecient.
