EasY Non-MessY TYe DYing of Tshirts and Pants, Including Instructions and Experimentation Results
Intro: EasY Non-MessY TYe DYing of Tshirts and Pants, Including Instructions and Experimentation Results
Take a bland shirt or pant and turn it into a multispectrum colorfest
STEP 1: Materials
Soda Ash : powder. $5 for 5 lb. use 1/3ish cup per gallon (16 cups = 1 gallon) of water. for single shirt I use 6ish cups of water so.... you don't need a ton of this stuff!. Some dyes (RYE?) come with soda ash in them. Procion does not.
n.b. The pool or hardware stores sell soda ash as sodium carbonate. Any pH upper will do! you want around pH 10 or 11 to fix "fiber reactive dye".
n.b. Arm&Hammer has a natural washing soda, sodium carbonate decahydrate, that contains water in addition to sodium carbonate, so use maybe 3 times as much.
Cold Water Fabric Dye : powder. $4 per little bottle (3 quarters (<--US currency) tall). 1 tablespoonish per shirt bag, will dye a second shirt, too. at least. I use Procion MX.
Some salt (tablespoon ish)
Some ziplock bags
Some gloves or plastic bags with rubber bands
A shirt or any kind of natural (cotton) fabric to dye.
Some ziplock bags
STEP 2: Soak Fabric in Soda Ash
Put the ratio of
1/3 ish cup soda ash powder
to
1 gallon water
in a zip lock bag.
You probably want to use enough water to cover the fabric.
Pour in the water, add the soda ash, close the bag and shake around, then add the fabric.
Let it sit half an hour.
This step matters. The soda ash prepares the fabric fibers to absorb dye. If you don't do this step the dye will fade dramatically in the wash.
to
1 gallon water
in a zip lock bag.
STEP 3: Soak Fabric in Dye
Put the ratio of
1 table spoon procion mx powder
to
6ish cups of water. luke warm.
Also add
a tablespoonish of salt
in a bag or bucket. shake or stir.
Consult packaging for exact quantities. Though experimenting will provide you with more flexibility in the future. The packaging doesn't know your goals, anyway.
I often resort to a large zip lock bag, but the mop bucket is a more environmentally friendly container if you're not going to save zip locks (if you do save them make sure to label them as NOT FOR FOOD, especially if you live in a coop like I do).
Fold/rubber band/tye fabric if dying with a pattern. I like to scrunch it up to get the crushed look in the pictures. No ties or rubber bands-- the key to crushed is to let the bag sit still and not move the dye around. The uneveness of the soda ash, salt and fabric layering and squishing will give the crushed effect.
On the other hand, for even color use a bucket and stir consistently. You can even put a large load in the washing machine.
Put the fabric, eg a shirt, in the bag/bucket. Add more water if necessary to cover the fabric. Seal the bag (if applicable) and squish out the air.
to
Also add
STEP 4: Remove Fabric From Bag/bucket and Let Sit Overnight
I recommend using gloves to take out the fabric, both to prevent your hand from getting discolored or contaminated. If you don't have gloves use plastic bags with rubber bands over the wrists. Grocery store produce-bags work best.
Take out the fabric. Ring dry (back into the bucket if reusing). Put into a plastic bag and let sit over night. You might be concerned that your neat pattern will now dilute and disappear. In my experience the dye does not spread. This step does help strengthen the color.
STEP 5: Wash and Dry
Put in washing machine or wash bucket (one of those small hand powered washers is perfect for a wash/rinse of this sort). Wash. You probably don't want to use soap or wash with other clothes.
Hang dry. (You can use a dryer but why waste energy?)
n.b. - the dye will respond well to discharge paste (discharge pigment) and acrylic (screen) paint. There are many instructables on this topic, so if you've never tried this technique check it out. You can also screen/bleach/discharge before dying.
15 Comments
legenda2012 12 years ago
pandaboy292 14 years ago
justkim 14 years ago
amarylis1234 16 years ago
camscam 14 years ago
https://www.instructables.com/id/Zip-Bag-Dyeing%3a-Jays-Patented-method-for-a-double-/
diN0bot 16 years ago
amarylis1234 15 years ago
SoupToNuts 15 years ago
allyrae89 16 years ago
fegundez1 16 years ago
camscam's dye post
