Introduction: UKP .31 Caliber (Universal Knex Pistol)
Here it is... what some of you might have been waiting for.
Key Features:
-Under barrel laser (non functioning)
-Trigger guard
-5 round removable mag
-3 round removable quick clip with a reload time around 1.5 seconds, you read right, 1.5 seconds
-Iron sights
-Yes, it is a slightly different handle system than the TDS... don't say its the same, please.
Cons:
-Small mag
-Accuracy is fairly low after 20 feet
Pros:
-Amazing look (in my opinion)
-20-40 foot range depending on bands, not bad for a pistol
-Fast fire rate, you can fire the 5 round mag in about 6 seconds
-Compact size
*All of these factors make this pistol a superb choice for a secondary in any Knex war*
I know someone somewhere is saying "but my oodammo pistol has the same fire rate and a 13 round mag and better range"
To that I say, "Then use it, but if you ever decide to look for a more tactical, realistic weapon to use as a secondary in a Knex war, then I suggest you come here first."
I know my weapon will not compete with an oodammo pistol... so don't say that... what I was going for with this a tactical weapon with good looks that could be used in a Knex war, and thats what I achieved.
Without further ado, I present: The UKP .31 cal (yes I did the math right this time... don't look at the forum topic... just don't... it's fail math conversions)
Key Features:
-Trigger guard
-Iron sights
Cons:
-Small mag
Pros:
-Compact size
Step 1: The Main Body
This is the main body of the gun... hence the title...
Follow the yellow boxes, they will provide you with useless information at most times, but that one time you need help, the yellow boxes will help.
*READ the box on pic 5... If the gun doesn't feed right because you didn't read it, don't complain...*
Step 2: The Handle
The barrel and handle are sort of merged together.. not 2 separate parts... so the build just continues building off the barrel... you'll see when you do it...
Please note the boxes If your a lefty, I built the gun being a righty... so the handle is formed for a righty. the boxes will tell you how to correct it for a lefty.
Step 3: Trigger
Easy enough...
Step 4: Fake Barrel
Simple
Step 5: Fake Laser and Real Trigger Guard
Well probably the most painful part of the build... and yes I forgot another picture... to finish the connection of the trigger guard just take the red 3 ways and slide them on the blue rod, really the only place it could go...
Step 6: Side Plates
Just to make the gun look better... build em' unless your way low on parts
Step 7: The Mag and Firing Pin
Last thing to build
Step 8: Loading and Firing
I'll have a video of this and other stuff... but for now...
The ammo is pictured below, and look its happy to see you!
Take 3 rounds for a quick clip or 5 for a standard clip, pictures of each below
To load a standard mag, insert the magazine with the green rod prongs pointed towards the back of the handle and push up until it doesn't go any farther... It locks in place internally, you'll here a click when the mag is all the way in... next get a ram rod and shove it through the bottom of the mag and attach a rubber band.... then pull the ram back and shoot.
To load a quick clip (my favorite, fastest reload) pre assemble the quick clip assembly... insert the mag the same way as a 5 round mag... then pull the blue pin and the gun is then loaded and ready to fire! around 1.5 seconds
