Introduction: ULTIMATE BREAK-FEAST SANDWICH (QUICK AND EASY TOO)
In this Instructable I will be showing you how to make a quick and tasty break-feast sandwich. I always make these sandwiches while I'm camping or just when I need a quick and filling bite to eat and the materials are relatively easy to transport. If you have anything to say then please leave a comment. This sandwich is tasty and really filling but it is also quick to make.
Step 1: Materials
1. Eggs (egg beaters is what I used)
2.Spam (bacon would work)
3. Pam
4. Bread
5. Butter (optional)
6. Frying pan
7. Plate
8. Bowl
Step 2: Preperation
1. Put the pan on the stove
2. Spray Pam onto the frying pan.
3. Turn the stove on to Medium heat.
4. Slice spam to slices that are a 1/4 of an inch thick.
5. If you are not using egg beaters and you are using regular eggs then prepare the eggs by separating them and mixing them in a large bowl.
Step 3: Cooking Not Burning
Pour the eggs on the frying pan and make the scrambled eggs. If you don't know how then just keep moving the eggs around with a fork. Take the fork and move the eggs from the outside in until the eggs are cooked. Once you have made your eggs then put them in a bowl and set them aside for later. If there is egg still sticking to the frying pan then don't scrape it off it will add extra flavor to the next step. While all this is going on put your bread in the toaster and turn it on.
Step 4: Cooking Not Burning 2
Take the spam out of the can and put it on a plate and cut into thin pieces that are about a quarter of an inch thick. Set your stove for medium heat and start frying the pieces. Cook the pieces for 2 minutes but it depends on how thick you cut the pieces. The pieces should be lightly browned on each side by the time you are done. If you do not want to use spam or don't have any then you can use bacon instead. But the spam would definitely fill you up better !
Step 5: Sandwich Time
The toast should be done by now. You do not want to add butter too soon because then you will have soggy toast, so you should add the butter after everything has been cooked. Take the toast and put it onto a plate and butter it. Next put as many pieces of spam as you want on the bread. And put a piece of cheese onto the spam. Now the eggs and you are done. This entire cooking project took me about 10 minutes. If you wanted to add some extra flavor then you could add some Tabasco sauce, pepper, etc. If you have some left over spam (cooked or uncooked) then you can put in a plastic container and cook (or heat) it up. If you come up with any of your own creations then please tell me in the comment section, enjoy !!!
