Introduction: USB Air Conditioning
Step 1: Box
Find the tin and make holes.
Step 2: Barrier
Make old cd barrier
Step 3: Connect and Lid
Connect USB cable with CPU Cooler
Step 4: Ice
Put ice (better - dry ice) :)
Step 5: Connect
and enjoy with cold air, sorry my English ;)
1 Person Made This Project!
- dwtech made it!
115 Comments
6 years ago
nice
6 years ago on Introduction
meh.. if the ice comes from a fridge in the same apartment, then you will be adding heat in your home. Not a big amount, but still this doesn't make much sense
8 years ago on Introduction
i have designed a similar version inspired by it that uses an arduino chip ATMega8
and controls the fan speed according to the amount of external temp.
it also warns that ice is melting , etc...
it also has a lcd display and humidity centre and is fully automatic and also monitors the battery level and recharges automatically when plugged in the socket..
it runs on 9 v dc...
it is so auto-cool.............................
Reply 6 years ago on Introduction
Dear HarshV... could you please draft your device's tutorial... a step-by-step one.... as i was thinking on the same ground but could'nt succed yet... thanks friend
7 years ago
sad to say that it did not work. it did blow cooler air, but so little that the heat you will produce while making this will be greater than the cooling you will get from all the ice your freezer can produce.... I really like the design and idea though. Maybe i didnt have all the right stuff for it.
9 years ago on Introduction
dude, this is so cool, where i live right now is soooo hot; this works so nicely and cost me nothing to make; but the ice goes away so quickly, it doesn't melt, it disintegrates, but the byproduct is freezing cold water that i'm considering to drink, good job on this 'ible
10 years ago on Introduction
can anione of u, help me out in designing this setup on basis of technical datas like( container volume, fan power,ice qty., temp. difference etc... ) required for 1 person nd for 15 persons ?
i'd try using a thermoelectric cooler {peltier unit}
11 years ago on Step 5
nice, but maybe I will try that one with a bigger container..maybe it can refresh a bigger room....nice project
Try it with more fans, and a larger container, like a cooler.
If you're doing that, use Ice packs (Such as Nordic Ice) or frozen water/gatorade bottles.
And use some fans to draw air in.
11 years ago on Introduction
nevermind.. i used whatever worked haha. i made one! sadly, the fan is so weak.. i can feel it drawing cold air out, but its really weak. is there... an easy way to... say, use two USB outlets to combine 10 volts to power the fan more? I made mine out of this big Tin box that a bottle of southern comfort came in.. its really cool. looks nice and its really tall! I love the idea.
Reply 11 years ago on Introduction
heres the pics of the version i made. Needs more juice in the fan area though. I used a plastic like CD case, it was bendy plastic to make holes in to hold the ice. It worked fine, drained without leaking. Cool instructable!
Ok, do as I did. I amped it up a little. I don't have pics now, but I will later.
Essentially, have one fan running air intake, and one to blow the air at you. Intake at the top, ice at the bottom, fan blowing air aimed at your face.
It's that simple, and all you have to do is rig it up to a single usb cord.
13 years ago on Introduction
its portable! you can use in car with an Ipod car charging usb thingy from apple!
Reply 13 years ago on Introduction
Or you could simply roll down the windows.
no it does not help in saskachewan
how many trees have you found so far?
i lived in edmonton for 6 months, not one tree
Oh. I don't imagine this cooling a whole car, though.
2 or 3 mabey, also try running the fans (of the car) with no heat or a/c
True.
