USB LG Phone Charger
Intro: USB LG Phone Charger
This instructable tells you how to make your LG phone charge from a USB port using a spare wall charger.
STEP 1: Getting Started
Look at the lable on your AC charger to make sure that the output is the same as a USB port(5v, 500mA). Take your wall charger and cut off the plug that goes into your phone. Then cut the USB cable to the desired length.
STEP 2: Sodering
Cut off the outside of the usb wire then strip the positive and negative wires inside the cable. Take apart the plug and cut off and pull out the wire that connects it to the wall plug. Then push the USB wire into the hole were the wire you just took out was. Soder the USB wires and the Plug wires together and tape the exposed metal to prevent shorting. Lastly reasemble the plug.
STEP 3: Finished Project
Your finished project might look like this. Mine works great and I've been using it ever since. Enjoy!
STEP 4: Further Development
Rather than throwing away the rest of your wall charger you could SOLDER a female USB port to the curcut bord so that you can still use the USB charging cable you just made with you wall charger. This is further explained in this Instructable.
42 Comments
HeatherT93 7 years ago
Are u selling the phone charger or just posting it as a ad?
nodoubtman 12 years ago
scrool down at the end of the page... i tried with 5 V DC 500 mA, doesnt work, only give me 600 mA of intensity, i think i should try 5 V DC 1 A, what do you think?
thank you!
marC:)
Gizmodan923 14 years ago
thank you!
strcrusher 13 years ago
Gizmodan923 13 years ago
Zrowny 14 years ago
rayfalcon 14 years ago
My charger for that Phone is model STA-P53WD
input 100-240V 50/60Hz 0.2A
output 5.6V 0.4A
truckinforjesus@windstream.net
waffleman 14 years ago
kiwiboy1964 14 years ago
Haruofwater 14 years ago
Rectifier 16 years ago
fjkl; 14 years ago
santy22 14 years ago
Grey_Wolfe 15 years ago
Rectifier 15 years ago
