UVIL: Backlit Blacklight Nightlight (or SteamPunk Indicator Lamp)
Intro: UVIL: Backlit Blacklight Nightlight (or SteamPunk Indicator Lamp)
How to put together an eerily glowing neo-retropostmodern ultraviolet indicator lamp.
This shows the construction of the first two that I made as a way to evaluate the PCB etching process outlined in another Instructable. My idea is to use these as indicator lamps in some other projects.
My son insisted that I enter it into the LED contest because he wants a TV-B-Gone kit, so be sure to vote it up if you like it. (Click the + icon at the top of this page)
You should open this pre-requisite Instructable in a new tab or window: https://www.instructables.com/id/Stop-using-Ferric-Chloride-etchant!--A-better-etc/
It is the method used to do the etching in this instructable and has the added bonus of giving the PCB's a nice green tint.
Eventually I will make stained wood and brushed aluminum enclosures for these. I also plan to make use of these as indicators on some projects. (They are actually quite significantly brighter than they appear in the pictures)
STEP 1: Gather Materials
Aside from the etching materials (which are listed in the separate Instructable noted) you will only need:
- Ultraviolet LED's - I got 200 for $10 on eBay. I think cool backlight effects could be made with any LED combination you like, my preference just happens to be UV.
- Fluorescent acrylic - McMaster carries this, as do alot of industrial supply houses. I got mine for $0.99 in the form of a tacky cutting board from a thrift store. Again, green is my preference, but the material comes in a couple of fluorescent colors. I think that maybe I'd like to try red, too.
- Standoffs - I used #8 threaded couplers
STEP 2: Layout the Top Board
You will be etching two boards. One will be the front/top (whatever you want to display) and the other will be the back/bottom, holding the batteries and UV LED's.
You can be pretty free laying out the top, just be sure to stay far enough back from the edges to clear your stand-offs and Remember to reverse your image for etching!
STEP 3: Etch the Top Board / Layout the Bottom Board
After etching the top board using the process outlined at https://www.instructables.com/id/Stop-using-Ferric-Chloride-etchant!--A-better-etc/ you will need another board to hold the LED's and batteries. The second board needs to be the same size as the first.
You will need to decide:
1.) How many UV LED's you want to use
2.) Where to place the LED's
3.) How to supply the power to the LED's
I took a little 1-LED coin-cell flashlight and replaced the white LED with a UV LED. This allowed me to shine from behind the board to see what different placements would look like. Bending the LED's over (rather than have them aimed at 90 degrees to the board) gives more coverage.
Once you have decided where to placed the LED's you need to decide where to place the battery (or power wires). You can get PCB-mount coin-cell holders - I cut a piece of battery contact from and old lamp, bent it, and riveted it to the board for one contact. The other contact is just a large pad on the board.
If you wonder why there are so many parallel traces on mine, it is because I wanted to see how well traces of different widths would come out of the etch.
STEP 4: Etch & Solder the Bottom Board / Cut Acrylic
After etching the bottom board and fixing the components in place you need to cut out the acrylic to size. Be sure to cut out for your standoffs, too.
This doesn't have to be pretty since it's only purpose is to diffuse and fluoresce in the background. In fact, I scuffed it up with some 100 grit sand paper to help diffusion.
STEP 5: Assemble / Gape and Genuflect
All three layers are now done - time to make a big green sandwich. Assembly is straight forward: Top layer on top, acrylic under that, PCB next.
A picture of my first UVIL assembly is below.
Also is a (wiggled, blurry) picture of the Olivian UVIL backside showing the roller limit switch I added so that you can turn it off just by laying it down. I wanted to use a tadly mercury switch but didn't have one on hand. Incidentally, The Olivian UVIL bottom PCB also used a sharpie pen as resist (rather than toner transfer)
22 Comments
LinuxH4x0r 16 years ago
RedBinary 16 years ago
AP Digital light 16 years ago
RedBinary 11 years ago
T-Hawke 13 years ago
RedBinary 13 years ago
Travellinman 13 years ago
kc5qnk 15 years ago
Dissension 15 years ago
Randomskk 16 years ago
I had the PCB on the back run off an ATtiny13, a coin cell and a push button that turns it on, causing it to fade the LEDs in and then out again.
I couldn't get my hands on any acrylic, so instead I just used three 3mm LEDs - they light up the PCB in front (FR2) quite nicely.
I made a quick build log of it:
http://negativeacknowledge.com/2008/03/02/mothers-day-08-a-light-up-box/
IamTheCreator 15 years ago
Randomskk 15 years ago
poeticoddity 16 years ago
igorgama 16 years ago
You can get the acrylic from McMaster if you don't feel like digging - I've never bought it from there, but I do know they carry it. I see alot at thrift stores an you can find clipboards to cut up at Wal-Mart, Target, OfficeMax, and the like.
Someone else had sent me a msg asking about getting started with etching so I looked around for some web pages that I thought would be useful:
Here's what I found:
http://www.headwize.com/projects/garbz2_prj.php
http://myweb.cableone.net/wheedal/pcb.htm * I had never read this one before - it's a little more technical way of doing the printout, but I think it may be a better way.
http://www.solarbotics.net/library/techniques/buildpcb_trnsfr.html
clamoring 16 years ago
IamTheCreator 16 years ago
