Ultimate Straw Rocket!
Intro: Ultimate Straw Rocket!
What is the "Ultimate Straw Rocket"?
Answer: A very easy to make rocket made from a drinking straw, and launched using air pressure.
Almost everyone will be able to make this, it does not require any hard-to-find items, but also can it be made in very little time. Therefore will the rockets themselves be very easy to mass produce.
They will fly HIGH up in the air, and then land on the ground, completely safe!
Okay let's get started!
STEP 1: Gathering Materials
As first said, the items are very easy to get, and you probably already have them lying around your house.
You will need to print following document to continue, though:
Download this .doc!
The rest of the materials are descriped in the picture.
Download this .doc!
STEP 2: Making the Rocket
Cut a 6cm piece of a straw.
Put a dot of hot glue in one end of the straw making sure it's air tight.
STEP 3: Attaching Fins
Now cut out a pair of fins from the printed document.
Then fold and glue the fins together. Stippled lines means "fold backwards", whereas straight lines means the opposite.
You can use hot glue to glue the fins together, but I find that white glue (Elmer's glue or wood glue) works well.
Then glue the backside (the white side) and attach it around the straw, approximately 1-1.5 cm from the open end of the straw.
STEP 4: Launch It!
The rocket is finished now! Wasn't that easy?
Now for launching it:
Insert it all the way down in the nozzle of the bike pump, and give the bike pump a good, fast pump! Now enjoy your small flying rockets...
I had my rockets to go as high as ~10 metres!
Don't forget goggles, you don't want the rocket in your, or everyone else's eyes.
Thanks to Peter Hald for inspiration.
95 Comments
mrvigil 1 year ago
https://drive.google.com/file/d/0BxnKP8t2CAc2WGlyVHlSQ2hhaUE/view?usp=sharing&resourcekey=0-jqLB6npYqRQfPv-nU_hzAQ
obasan 6 years ago
The fin pattern document is no longer available. I tried searching on Google, but couldn't find a similar fin. Does anyone have a source? Thanks
mrvigil 6 years ago
https://drive.google.com/file/d/0BxnKP8t2CAc2WGlyV...
curtis14 8 years ago
tried it on the air conpressor
samdadbob 8 years ago
Did it work? If so how high did it fly?
austin42 10 years ago
ever tried making it a dart
122717 10 years ago
an1153 12 years ago
doo da do 11 years ago
retrotimelord 12 years ago
an1153 12 years ago
Puck13 13 years ago
cornonthecobert 12 years ago
Echo2000 15 years ago
http://www.flashnet.dk/files/fin.doc
hjjusa 12 years ago
JudyT 13 years ago
spankeerrrrrrr 12 years ago
farlandhunter 12 years ago
nhackenberg 12 years ago
jtalvy 13 years ago
