Introduction: Ultra Bass Circuit Without IC & Transistors
THAT CIRCUIT AS A BASS CIRCUIT WITHOUT IC & TRANSISTORS
Step 1: Capacitors
Need Capacitors.
2* 100uf 16v
1* 1000uf 16v
capacitors works here for changing frequencies
Step 2: VOLUME
IT WORKS AS A CONTROL BASS IN THIS CIRCUIT..
Step 3: CONNECTION
CAPACITORS VE- IS CONNECTED IN VOLUME 3RD
Step 4: CONNECTION
ANOTHER CAPACITOR VE+ IS CONNECTED IN VOLUME 1ST PIN THEN BOTH CAPACITORS IS CONNECTED IN SERIES
Step 5: CONNECTION
16V 1000UF ve+ IS CONNECTED IN PARALLEL CONNECT IN 100UF VE+
16v 1000uf ve- IS CONNECTED IN 100UF VE- IN 3RD PIN
Step 6: AUX CABLE
Step 7: AUX CABLE
AUX GND IS CONNECTED IN 3RD OF VOLUME
Step 8: AUX CABLE
AUX LEFT, &, RIGHT IS CONNECTED IN VE+ IN VOLUME 1ST PIN
Step 9: ANY AMPLIFIER BOARD
I AM USING HERE 24V.0.24V AMPLIFER BOARD
AS YOU SEE IN PHOTO THERE IS AUDIO IN & GND
Step 10: CONNECTION
AMPLIFER BOARD INPUT IN CONNECTED IN BASS CIRCUIT IN 2ND PIN
Step 11: CONNECTION
AMPLIFIER GND IS CONNECTED IN BASS GND
Step 12: REVIEW
CIRCUIT IS READY FOR TESTING
Step 13: LET'S TEST
CONNECT AUX IN YOUR MOBILE AND ENJOYING THE MUSICS..
Step 14: SPONSORED
THIS ARTICLES IS SPONSORED BY JLCPCB
Step 15: ORDER TO JLCPCB
HERE UPLOAD YOUR GERBLE FILE.
THEN SELECT YOUR QUANTITIES.BOARD SIZE.COLOURS ..AND SO ON..
Step 16: ORDER TO JLCPCB
AFTER THAT CLICK ON CHECK OUT SECURELY
Step 17: PAYMENT METHOD
SELECT YOUR SHIPING ADDRESS AND PAYMENT THEN ORDER IT..
