Unclog Sink Revised
Intro: Unclog Sink Revised
So this picture shows my first attempt, which worked but I added a chrome piece to fit my sink water outlet perfectly. Also someone mentioned about the overflow hole, one could make a cork type of device to plug it but I prefer my thumb. Cheers!
STEP 1: Tools and Parts
List of tools: flat head screwdriver
List of parts: small plunger head around $5, Danco 10506 dishwasher aerator adaptor chrome $5.75 free shipping, 5/8" hose(length depends on you're particular sink), hose clamps around $1, and 5/8" barbed fitting.
STEP 2: Drill a Hole
Grab the plunger and make a hole with a drill through the bottom.
STEP 3: Fittings
Each fitting will go on either end of the hose. The chrome piece fit perfectly on to my sink water outlet after I took the piece that was originally there. It works better if you screw in the chrome piece first and then adapt the hose with plunger.
STEP 4: Connect Plunger
The barbed fitting you get from the hardware store must fit the plunger you intend on using on its threaded end.
STEP 5: Clamps
Slide the hose into the chrome adapter and tighten the clamps at shown points to prevent water leakage.
14 Comments
doo da do 8 years ago
Another thing that works, run water till hot. Put a couple Alka seltzer in drain, let set for about 10 min. Stop drain with plug, fill sink with hot water, pull plug and you should be in great shape.
OnlyForever88 8 years ago
JackB64 8 years ago
just recently I cleared my daughters sink [and do it with my own all the time ]with a small plunger and my hand of the overflow hole ,worked like a char ,I dont see the need to build this device ,,, great job though if it worked
thomcomstock 8 years ago
Great idea!
How did you plug the overflow hole(s) at the top of the sink?
alfadog67 8 years ago
I second that emotion ;-)
rafununu 8 years ago
Eh eh, clever guy !
AnthonyW60 8 years ago
mooshi771 8 years ago
