Under Water Laser!
Intro: Under Water Laser!
Today I will show you how to make any laser water proof!! Amazingly its very cheap and easy to do!
STEP 1: Step 1: Materials
To do this you need:
-a laser pointer
-saran wrap
optional:
-heat shrink tubing
-a lighter
STEP 2: Step 2: Get the Saran Wrap
Measure out a piece of saran wrap about a foot by a foot. You want it so that there is at least 2 inches showing at the end of the laser and half a foot on the top and bottom of the laser if you put the laser in the middle.
STEP 3: Step 3: Wrapping
Place the laser so that there is one inch of wrap below it and almost an foot above it. It also has to be centered so that there is about 2 inches or so on each side. fold the smaller bottom part of the wrap over the laser. Then fold the 2 inch side sections on each side inward so that the whole wrap is the width of the laser. You want to make sure the part over the laser hole is flat so it will shine a stright beam. Then roll and wrap the laser tightly in the wrap but not tight enough to press the on button down.
STEP 4: Step 4 (optional): Heat Shrink Tubing
Take the heat shrink tubing and place the laser inside it. Cut off any extra piece hanging over the edge but becareful not to cut the wrap. After aplying it use the lighter to heat it so it shrinks over the laser and secures it. I did this later and forgot to take pictures im very sorry about that.
STEP 5: Step 5: Test It
Fill your sink with water and try it out! Its so cool! You can take it with you in the pool and shine it across to your friends! Have fun!
3 Comments
Adambowker98 11 years ago
yaaarrrr 12 years ago
joey99 13 years ago
